M20B25 Start, Idle, die (RESOLVED)
  • Denny
    • Jan 2010
    • 822
    Guys
    Last 2 days been trying to diagnose this weird problem with my M20B25 engine.
    I was tuning it and it was running fine...then when I approached a light and pressed on the clutch and brake the car would stall (but restarted right away) did it about 5 times so I drove back home and let her sit for the night.
    The next day (cold start)
    1.car cranks over,
    2.engine catches/starts
    3. idles (goes from 700rpm-1500rpm...down to 600rpm-1200rpm and then down to 400rpm-800rpm and finally dies down (idles for about 5-6 seconds total)
    Now If I try again right after it only idles (2-3 seconds) dies right after.
    Troubleshooting so far.
    1. Compression on cylinders (150,145,145,150,150,150) so am good here actually surprised I sent over 13PSI on this engine
    2. Checked for air leaks
    3. Sparkplugs are wet with fuel
    4. Spark is present as car starts
    What would you check at this point? any help is greatly appreciated.
    **When I resolve this I will document this to be able to help others.
    Denny
    ___________
    1990 BMW red 325IC M30B35 all stock Girlfriends ride
    1991 BMW black 318IC (M62b44 Megasquirt 2 ver 3.57)
    Blogs:
    http://bmw325e30.blogspot.com/ (restoration)
    http://bmw325e30turbo.blogspot.com (Twincharge M20)
    http://bmw325e30m62b44.blogspot.ca/
  • Just Scott
    • Dec 2010
    • 140
    Check more for vacuum leaks - had a similar issue and fixed it by replacing the vacuum line between the intake manifold and the fuel pressure regulator.
    Pressing the brake, makes me think vacuum of some sort since the booster is vacuum assist.
    But honestly, I'm just guessing. The Bentleys can walk you through this probably.
    1990 325is - sterling silver, very nice, maybe for sale
    • Denny
      • Jan 2010
      • 822
      Im going to check even more for vaccum leaks...
      It stalls out when I press on the clutch to come to a stop sorry for confusing with the braking... like it cant return to idle.
      Engine warm will restart and idle and cold will start but not keep an idle.
      I got the book just looking for real live experience
      Denny
      ___________
      Blogs:
        The first thing to rule out would be intake leaks. Have a shop run a smoke test.
        • Denny
          • Jan 2010
          • 822
          Thanks, but I dont want to pay 300$ to get my car towed to a shop as right now I cant drive it. Any tips tricks on a cheap way I could test for leaks by doing a smoke test at home? I checked visually for leaks but I know thats not very effective..
          Denny
          ___________
          Blogs:
            The only way you can do a smoke test is with a smoke machine. The cheapest off the shelf machines are about $1000. There are some articles on the web about how to make a machine that will work. As a guess I'd say you could build one for about $100 that would get the job done.
            • Denny
              • Jan 2010
              • 822
              thanks man appreciate it. You got me motivated to build one, NA or not since am always going to be forced inducted this tool am sure will be useful in the future too.... no room for any air leaks.
              One quick google search and check this out:
              http://www.fiero.nl/forum/Forum1/HTML/081547.html
              Denny
              ___________
              Blogs:
              • Denny
                • Jan 2010
                • 822
                Well tonight I did some more testing on the car (while I build a air leak tester)
                1.Crank over
                2.Start
                4. Crank again same results but idle lasts 2 seconds
                5.crank again and no more start exept this time i try to give it gas and my vaccum gauge/boost goes to 3-4psi?!? and back down to 0 vaccum and dies
                now am sure the car is flooded with fuel... :(
                things checked tonight:
                1. Coil is good
                2. wires, rotors, dist and Coolant temp sensor all good
                I looked over again everywhere and cant find leaks...
                According to this anybody know if this could still be a vaccum leak? or is this pointing to something in particular?
                Denny
                ___________
                Blogs:
                • dnguyen1963
                  • Nov 2011
                  • 2651
                  search www.scottykilmer.com for cigar smoke test.
                  • Denny
                    • Jan 2010
                    • 822
                    thanks man. that guy Scotty is funny lol... the cigar trick is a pretty cheap alternative.
                    I gave it a shot and no leaks... :(
                    I hope I dont have to pull the 30# injectors (now am wondering thsi all happen when I went for a ride and hit 13PSI) did I hit max dutycycle and one or all of the injectors stayed open? what are the odds?
                    Denny
                    ___________
                    Blogs:
                    • Denny
                      • Jan 2010
                      • 822
                      ****RESOLVED!!****
                      I GOT Fire....I GOT Fuel.... Give me a better 12+V connection for my MILLER MAF LOL...
                      I had used those pesky little blue connectors to splice in 12+ grey wire to the big blue/red wire in the ECU plug for my MILLER MAF and with time it disconnected slightly to give me days and days of headaches...
                      Over and out! thanks to those that took time to help. Hope this helps others
                      Denny
                      ___________
                      Blogs:
