Engine shaking while started up.
  • e30m3ochoa
    • Aug 2012
    • 136
    To this morning I went to turn in my car and at first it didn't want to turn on so I kept trying and then it did but it would stall. Then it would stay on but the rpms were so unstable and it was shaking. Any ideas? I didn't have time to check anything cause I was headed for work.
  • a3ternus
    • 643
    Spark plug wires?
    Just a guess...
    N.
    Originally Posted by aaron_silva
    It is always frustrating having a harsh ride when
    you arent in the right mind set.
    • TG Goose
      • Jul 2011
      • 234
      fueling issue, check fuel pressure
      ______________________________________
      1984 LSB 318i - Sold
      1986 325i - Motor Swapped Track Car Project
      1995 318ti - Sold
      1999 540iA - Daily Driver
      • dnguyen1963
        • Nov 2011
        • 2649
        Vacuum leaks...
        • e30m3ochoa
          • Aug 2012
          • 136
          Yeah I was thinking it would be a vacuum leak but I started with checking the spark plugs and they were pretty burned already so I will be replacing them tomorrow. What would be the best way to check for leaks?
          • dnguyen1963
            • Nov 2011
            • 2649
            Smoke test is the only reliable way to check for all vacuum leaks.
            • ADEN
              • 620
              soooo correct, black and slightly wet spark plugs are a clear result of fuel problem.
              probably defected pump, clogged filter or FPR
              • e30m3ochoa
                • Aug 2012
                • 136
                How would I be able to do that at home since I don't have a smoke machine or anything of that sort?
                • e30m3ochoa
                  • Aug 2012
                  • 136
                  Well I did have black spark plugs and oil I them so how would I go about checking all of that?
