parts list?
  • ahalfacre5
    • Aug 2012
    • 156
    parts list?
    so the pistons in my 325is are all done.. head is done.. ive got a 325is long block in good running condition coming. i considered replacing the pistons with the good ones but after some thinking and reading, i think ive decided that im just gonna swap. the guy im getting the engine from said its pretty much just the engine and the head but ive obviously got everything that needs to go on the engine. so i have a few questions,
    does anyone have a full list of things i need to get for an m20 to m20 swap? gaskets and all
    does it matter if the engine is from a later or older model as far as wiring and fitment?
    and, will the bently or haynes walk me through this pretty much? or does someone have a write up?
    what else can/needs to be done while the engine is out, im gonna respray the engine bay and clean up the wiring but what else should i do with the tranny and everything else
    sorry to everyone who has already answred questions.. i feel as if ive been bi polar with this. thanks again to everyone
    1986 325es
  • 5Toes
    • 9836
    Its not hard. Just ahve the right tools around
    Metric wrench set, metric socket set, an engine hoist, a few friends, and some screwdrivers, lol
    Pull it out as one piece, just hook it up to the engine hoist hook on the front of the engine. It will be scary but dont worry it will work.
    lay the combo on a pallet and then go to work, lol
    • ahalfacre5
      • Aug 2012
      • 156
      what about tranny gaskets?
      1986 325es
      • 5Toes
        • 9836
        Order the seals and install them on the pallet?
        • Massimo
          • Jan 2008
          • 3207
          5 TOES what he said. Plus a Big Fucking Hammer never hurt anybody, or did it.
          • ahalfacre5
            • Aug 2012
            • 156
            rear main seal? never done tranny work... ever
            1986 325es
            • 5Toes
              • 9836
              As you take things apart you will see what would be hard to do on car. Do everything that you woudlnt want to do later. lol
              Id include rear main in that category
              • MR E30 325is
                • Dec 2008
                • 3300
                If the transmission isnt leaking now dont worry about swapping any gaskets.
                There arent any gaskets you will need to replace due to you switching the transmission from one m20 to another, unless you damage one in the transition process.
                If you really want to do the rear main seal to be preventative about a leak I would recommend that you invest in a Bentley manual for the E30. They are available via Amazon. It isnt a difficult job, but you sound like the type of car guy who could use very clear cut instructions, and this book provides them.
                Invest in some sort of torch to heat up stubborn nuts and bolts. Especially if you want to replace the rear main seal. I have recently picked one up myself and it makes things much much easier 95% of the time.
                My previous build (currently E30-less)
                http://www.r3vlimited.com/board/showthread.php?t=170390
                A 2016 Toyota Tacoma TRD 4x4 Offroad in Inferno is my newest obsession
                • ahalfacre5
                  • Aug 2012
                  • 156
                  i don't really need clear cut instructions ive just been in the middle of too many jobs and not had the right parts, tools ect. so im making sure ive got what I need
                  1986 325es
                  • MR E30 325is
                    • Dec 2008
                    • 3300
                    Irregardless of that fact, I would still recommend you invest in a Bentley. It will give you a much clearer mental picture of what tools you will need to complete a project than simply asking on a forum.
                    • ahalfacre5
                      • Aug 2012
                      • 156
                      oh one other thing... does my wiring harness matter as far as the year of the new engine goes?
                      1986 325es
                      • mkcman17
                        • Jul 2010
                        • 8240
                        lol...irregardless...
                        any b25 or supereta harness will do.
                        you'll find that if you wait until swap day to do the gaskets and seals...you'll spend a LONG time on them.
                        1989 LN106 Hilux / 3.0TD SFA
                        1974 2002tii / stock
                        2002 IS300 / 5spd LSD
                        • ak-
                          • 12422
                          Remember to remove your oil pan ground wire.
                          It seems to be a forgetful habit following friends and I.
                          1991 325iS turbo
                          • mkcman17
                            • Jul 2010
                            • 8240
                            and the slave. i've gnarled up those fittings a couple times.
                            • graveshaker
                              • Sep 2009
                              • 828
                              My senior supervisor used irregardless in a huttle meeting and I chuckled.
