fresh engine... no spark... calling all m20 guys
    hey guys
    I just put in a fresh m20 in my 325is. ive got everything put in right as far as I know, no start. it will crank for days but wont fire at all. starting fluid doesn't help. I watched thespark a few min ago, and every 4-5 roatations I get spark but its not steady at all... I think im getting fuel because when I crank with the plugeout everycouple of rotations, something (I assume gas) puffs out of the plug hole.
    anything you guys know will help I wanna get this car back on the road!!!!!
    1986 325es
    Sounds like a faulty coil?
    also make sure your plug wires are right
      how can you test the coil? and I 99% my plug wires are right
      1986 325es
        Could also be a goofy crank position sensor, or the impulse sender on the #6 wire could be bad. I'd guess the crank sensor.
          Or you could have the crank position sensor and impulse sensor reversed. The plugs are not unique. I've done that one before
            I left the crank sensor plugged in when I pulled the old engine so I know its not that... but ill double check... unless something broke while the car sat without en engine, I must have something wrong because everything worked when I pulled the old engine
            1986 325es
              CPS and whatever that other connector is, I don't remember, connected backwards can do that. I did it.
              They clip in under the diagnostic hat thingy. Fuck me today, I can't think to save my life.
                im now getting intermediate spark... I seems like it is firing correctly for the most part... and I have fuel to the fuel rail no problem...... hmmm any thoughts?
                1986 325es
                  i checked the wires all good there... its stuttering like it wants to start but im still not getting much.... oh... and its puffing out the tail pipes...
                  1986 325es
                    so i do think i messed something up putting it back together... if i try to start the car in neutral... nothing if i put it in gear and hold the clutch in, it moves like it would i i put it in gear with and tried starting it without the clutch held in
                    1986 325es
                      So it won't start in neutral, but it will try to start in gear? And when in gear with the clutch pedal down, the engine is transmitting power to the wheels? Sounds like you've got 2 very different problems.
                        yeah... sort of... im not sure if it will try to start in gear... but what could thst be?
                        1986 325es
                          bummmmp
                          1986 325es
                            Sounds like a CPS issue.
                            Originally posted by audiquattrot
                            bimmers b4 b*tches....remember that.
                            1990 Alpinweiss 325i - secret 500whp build
                            2000 Audi S4 B5 Laser Red
                            1990 Nissan 240sx - Drift Missile
                            2006 CBR600RR
                              Water Temp. Sensor?
                              M20B28 Turbo
                              My Build Thread
                              http://www.r3vlimited.com/board/showthread.php?t=255839
