High idle after afm and icv cleaning - **FIXED** SEE LAST POST
  • amcink
    • 788
    Originally posted by dnguyen1963
    Have you tried to wiggle the elbow going into the throttle body? Every time someone tries to clean the ICV, he/she always manages to make that connection loose.
    Yeah that thing is thight
    • AlphaE
      • Sep 2011
      • 503
      only difference from before you did the work and now is that you created a vacumm leak..
      This morning= before you messed w it= no vacumm leak=ran normal
      Now=after you messed w it= vacumm leak= runs like pooh
      the odds of messing something up the actual idle valve are slim to none i would think.
      SMOKE IT!!
      Now with 2.7i power!!!
      • amcink
        • 788
        Ok just smoke it with some marlboro and that thing is thigh nothing came out. And the car still fluctuate between 1k to 1.5k. I unplug the ICV while it was running and it revs up to 2k and then keeps goes back and forth. I believe i mess up the ICV. Any thoughts?
        • dnguyen1963
          • Nov 2011
          • 2648
          You need to keep the pressure between 2-4 psi if you want to find vacuum leaks.
          • amcink
            • 788
            I was able to get smoke smoke out of the hole on the elbow where the idle control valve goes (since i used the hose from the elbow to the icv to blow smoke. So it did a full circle
            • FLG
              • Sep 2011
              • 3165
              Again..
              You need it done right.
              Sent from my Galaxy Nexus using Tapatalk 2
              -Build http://www.r3vlimited.com/board/showthread.php?t=295277
              • amcink
                • 788
                Found a great article on how to test the idle system. I will follow it and see what i found.
                • amcink
                  • 788
                  **FIXED**
                  Ok, So i follow the ICV section of the above link. I test the ohms and it was fine.
                  Then i took the ICV off again and did a better job on cleaning it. It seems that my ICV was full of gunk and my first try of cleaning created a problem since i did not took out all the gunk out and the gunk that was left keep the ICV from closing; therefore creating a vacuum so the continuous surge of the idle.
                  After a through cleaning and carefully turning the inside of the ICV (to try to hit all the areas and clean out all the gunk) I test it by plugging back the electrical plug to the 2 prongs but not installing the hoses; then turning the key to the 1st position and verifying that the ICV inside closes properly (I did this few times to make sure it was closing properly). Finally I install all back and started the car and the idle is at 900 with out any surge. I also adjusted a little the screw on the ICV to manage the air flow and everything is working fine at this time. Idle is perfect at 900 and the car sound great.
                  UPDATE - ok ICV was gone i clean it too much that the computer could not control it. It was idling at 900 the creep to 1200 and the started oscillating again. I got one from a fanatic. Did a quick clean and install it. Idle is perfect. So make sure you use carb cleaner and NOT break cleaner and never a wd40.
