My temp gauge does not get to the middle. So i do not know of the car is running hot or not.
Why my temp gauge does not get to the middle?
I've heard of many E30s running just below the center of the gauge and some a little above the 1/4 mark, neither of which is an issue.Interested in vintage cars? Ever thought about racing one? Info, photos, videos, and more can be found at www.michaelsvintageracing.com!
Elva Courier build thread here!Comment
which termostat do you have?sigpic
Levent
%20levent@gutenparts.com
Ladies:
1998 E36 m3/4/5 1988 325i 1989 325iTComment
Either:
1. Your thermostat is stuck open/broken and forevercooling your motor.
2. You actually have an 80c thermo (or whatever the lower one is).
3. Your temp gauge sensor (the brown plug on the thermo housing, not blue) is poopoo.
4. Temp gauge itself is busted (doubt it)
I don't think you're overheating. The worst outcome of the scenario is getting worse gas mileage and possibly less power.Comment
You should also check your SI board/batteries. Many of the temp gauge problems are due to bad SI board/batteries.Comment
Either:
1. Your thermostat is stuck open/broken and forevercooling your motor. This is new so I doubt
2. You actually have an 80c thermo (or whatever the lower one is). This is possible I will check my purchase order. It was about 6 month ago
3. Your temp gauge sensor (the brown plug on the thermo housing, not blue) is poopoo. I feel this could be the culprit
4. Temp gauge itself is busted (doubt it) Doubt it but will check the batteries as
mention on the post aboveComment
bad ground on the back of the gauge can mess it up. mine read really wacky and sometimes even waved hi to me.
tightened and cleaned up that nut on the back of the gauge and it behaved/read normal.Comment
You are into something since my gas gauge at times did not marked correctly and i need to push the back of it to make the needle move and mark the correct gas. It stopped doing it for sometime now. I will apply pressure on the back of the temp gauge maybe it will work.Comment
