Piston to Cylinder Clearance
  • z122643
    • Aug 2011
    • 286
    So... after checking every source I have available to me I have discovered that my piston to cylinder wall clearance should be .0004"-.0016"
    Anyone else find this to be a tight fit?
    [/SIGPIC]"we are so totally screwed!"
  • z122643
    • Aug 2011
    • 286
    Anyone?
    Also does anyone know what the center to center measure is the for the cylinder bore?
    • ttrousdell
      • Nov 2009
      • 1770
      My chilton says the piston to bore clearance for a new engine is .0004 to .0016" and used is .005". Most of the engines ive rebuit had clearances around .003 so yea its on the tight side.
      The Build:
      • LJ851
        • 7918
        Piston clearance depends on lots of things. OEM cast piston (low expansion) ? Your numbers sound about right. Make it a forged piston and the numbers will be a lot different unless it has a very aggressive slipper skirt.
        Lorin
        The M30 is God's engine.
