Post Valve Adjustment
  • cutsham
    • Sep 2012
    • 166
    Does this sound normal? Thanks!
    Previous Cars:
    89 325i M-Tech II
    00 323i
    89 535i
    89 325i Vert
    Current:
    01 Hellrot 330ci
    91 Alpine 318i Build Thread
    01 Jeep Cherokee (Winter Beater)
  • ttrousdell
    • Nov 2009
    • 1770
    they always tick. is this the first time you have done an adjustment?
    The Build:
    • cutsham
      • Sep 2012
      • 166
      Yeah, had a leaving valve cover gasket, so figured while I was in there I would get it done. All spaced to the proper .25mm/.010 in.
      Here's a before video, from the other side of the engine though:
      Previous Cars:
      89 325i M-Tech II
      00 323i
      89 535i
      89 325i Vert
      Current:
      01 Hellrot 330ci
        Was that video taken with the engine up to normal temperature? Properly adjusted valves will "tic" when the engine is cold, but will quieten down once the engine is at temperature.
        If the engine as at temperature, either you didn't properly adjust the valves or the valve guides are worn. In the latter case they'll always make noise until the head is rebuilt.
        • cutsham
          • Sep 2012
          • 166
          When I took the video the engine had only been running for less than 5 minutes. It was also in the forties outside. Same for the before video. I'll have to take it for a drive and check it out. Hopefully this is it.
          Thanks!
          Previous Cars:
          89 325i M-Tech II
          00 323i
          89 535i
          89 325i Vert
          Current:
          01 Hellrot 330ci
          • cutsham
            • Sep 2012
            • 166
            Also, the engine only has 98,000 miles on it.
            Previous Cars:
            89 325i M-Tech II
            00 323i
            89 535i
            89 325i Vert
            Current:
            01 Hellrot 330ci
            • cutsham
              • Sep 2012
              • 166
              Drove the car around tonight, and got it all warmed up, so heres a new video haha:
              Normal? or Bad? Still have to fix my rough idle, so not sure if that plays a role. Also, the engine is running mobil 1 synthetic 5w30. Would switching to the recommended 20w50 help?
              Previous Cars:
              89 325i M-Tech II
              00 323i
              89 535i
              89 325i Vert
              Current:
              01 Hellrot 330ci
              • Cabriolet
                • 9620
                ya those valves are too loose. get a valve adjustment done.
                Much wow
                I hate 4 doors
                • E30Gus
                  • Jun 2008
                  • 781
                  I wouldn't run 20W50 in CT during Winter time.
                  • dnguyen1963
                    • Nov 2011
                    • 2648
                    Switch over to Rotella 15W40 (I would not go any thicker during winter time) to see if that will quiet down the valves. If not, redo the valve adjustment.
                      The oil used will have little to no affect on valve noise since these engines have mechanical lifters.
                      • dnguyen1963
                        • Nov 2011
                        • 2648
                        True, but I used to run the car with 5W30 in the dead of winter and the engine did tic a lot louder. It was much quieter with 15W40...just my practical experience.
                        • cutsham
                          • Sep 2012
                          • 166
                          I'll try that when I change my oil. Even if it doesn't make much of a difference, it won't do any harm.
                          Previous Cars:
                          89 325i M-Tech II
                          00 323i
                          89 535i
                          89 325i Vert
                          Current:
                          01 Hellrot 330ci
                          • cutsham
                            • Sep 2012
                            • 166
                            Also, could anyone help describe the adjustment process a little better? The Bentley manual and every where else says there should be "slight drag" on the feeler gauge. How tight should the gauge be? I definitely had drag, as in I could slide the gauge back and forth fairly easily, but it was definitely dragging and both parts, if that makes any sense haha.
                            Previous Cars:
                            89 325i M-Tech II
                            00 323i
                            89 535i
                            89 325i Vert
                            Current:
                            01 Hellrot 330ci
                            • dnguyen1963
                              • Nov 2011
                              • 2648
                              If you can move the gauge easily then it is too loose. There should be decent amount of resistance, but not enough to stop moving the gauge.
