1985 325e Not Starting
  • bcusitsjeff
    • Mar 2012
    • 145
    hey guys i got a bit of a problem...
    last week i changed my oil pan, and it wouldnt start, it wasnt getting any spark. so i checked the distributor and it worked fine. i then checked the ignition coil and it checked out fine. i was getting frustrated and so i checked all my fuses in the fuse box and came across a blown fuse either 27 or 28 i forgot exactly but it was one of those 30 amp fuses...
    and it started. i thought it was weird though because i dont think they have anything to do with ignition...
    the car was running fine, and i decided to flush my radiator. I then turned off the car. a couple of hours later when i went to go start my car again, nothing. it wont start anymore. i rechecked the fuses and they were ALL fine.
    now im stumped and cant figure what would be wrong. any ideas?
  • camip
    • Nov 2011
    • 1253
    Did you take off the engine ground wire and forget to put it back on? It's the only thing down there I can think that would mess something up.
