Hey Guys,
Did some searching with no luck and thought I'd reach out to the group.
Just installed a Miller MAF Conversion Gen III on my stock 1987 325is.
It's running extremely rich, raw fuel pumping right out the exhaust.
I found the MAF troubleshooting document on their website and performed the necessary tests. I've confirmed I have battery voltage at terminal 3 on the AFM plug. I've also confirmed I have 1 Volt at terminal 2 with the key in the on position.
The question I have is what the proper reading should be at idle with the engine running. I'm currently reading 2.1 Volts when it calls for 1.5 Volts. Also, as I rev the engine up, it seems to only max out at around 5 Volts. Is this correct?
I've also tested the TP sensor and everything reads as it should when at idle, partially open and at WOT.
Any suggestions would be greatly appreciated!
Thanks,
AJ
Thanks,
AJ
