eta 885 head stroker qeustion
  • e30m20TurbO7
    • 1203
    people who have a 885 head on a eta bottom end stroker , what are your compression numbers? i mean compression test result numbers not compression ratio's
    need to know because my numbers just seem to low, have not put any oil in the cylinder to see if it changes or makes it higher
    but the compression numbers are all the same with in a few pounds but just seems to low
    90psi all the way across
    it holds compression in all cylinders
  • travish325
    • Jun 2012
    • 1151
    I think its around 8.2ish
    edit here- http://www.r3vlimited.com/board/showthread.php?t=95445
    looks like 8.42:1
      • 37833
      He said compression test numbers. Not compression ratio.
      Grover Beach, California
      BimmerHeads.com
      • e30m20TurbO7
        • 1203
        thank you matt
        • travish325
          • Jun 2012
          • 1151
          didnt think it said that when I replied
          • travish325
            • Jun 2012
            • 1151
            And since Im nice Ill search for you again cause no one else seems to want to help
            ^whuuuut??????
            • e30m20TurbO7
              • 1203
              thank you i appreciate the help
              ^whuuuut??????
              • e30m20TurbO7
                • 1203
                still can use other peoples info if they had it since i already have read through the thread posted above, wanted to see if anyone had readings as low as mine
                • travish325
                  • Jun 2012
                  • 1151
                  Im gonna go ahead and say yours is pretty low
