whats a good way to get horse on a e30 with bolt on , i heard a diff wont do much . and neither will cams or maf. any ideas or suggestions ?? thanks
e30 peformance ?
Tags: None
i have a m20 . but im looking for easy stuff headers injectors ? stuff like that not ready for a swapComment
Im sure there are a ton of threads on here for performance adders.
M20 bolt on.
First off ya a diff dosnt make your engine make more HP it makes better use of the HP you have. Or worse if you go the wrong the wrong way.
The M20 is pretty tweaked as is so bolts on's dont do much.
As noted above a chip will do wonders. Seat of the pants noticable.
A maf swap is a great way to go the stock barn door meter is terrible.
I like and run the miller MAF and WAR chip and like it cause it uses the stock ECU
If you buy a cold air intake and keep the stock AFM make sure you keep the velocity stack with it or you will lose power.
Just a few ideas
Oh and search around I am sure you can find plenty of info.sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713Comment
