Alright guys...I searched around and couldn't find anything.
I have two issues!
I just recently built an m20b25 to a 3.1liter stroker for my 91' 325ix
It's been about 4,000 miles since I put the motor in. It was professionally built and professionally installed in the car and cost about $6000 so I'm not looking forward to spending more money on it.
Yesterday morning I went to go to work and heard a very loud knock/ticking noise. So I shut it off and had my dad drive me to work.
Next day I backed it into the garage and almost cried listening to the knock. So we adjusted the valves started it up and the sound was still present. The video at the bottom is my car and it should give you a good idea of what it sounds like.
We decided since it was dead and in the garage it would be a good time to replace the tps (which had been bad since the motor was put in.)
After putting it in we started the car, the check engine light turned off, but the car idled to 1500 rpm and started climbing the rpm. So I'm not sure what we did wrong. We followed pelicans tutorial by turning the tps until it gave continuity and then screwing it down. Is this the correct way to install it? (Can you tell me he correct way?)
Video showing the knocking sound and 1500rpm idle which started to rise up past 2200 after the video stopped (Please forgive the power steering pump noises)
Any help or advice would be much appreciated! Thanks guys!
I have two issues!
