Valves or injectors ticking?
  • Daeldalus
    • Nov 2012
    • 304
    I just swapped my old leaky 14# injectors for some flow matched e36
    injectors. at the same time i replaced my valve cover gasket.
    before the swap I had a very faint ticking that was almost certainly just the
    injectors, after the swap the ticking is a little over twice as loud
    (can't hear it without the hood open) so would it just be that the new injectors are that
    much louder or could i have done something that made the valves tick?
    should i check to see what my valves are currently adjusted to and make a
    decision based on that?
  • SlamedIAm
    • May 2011
    • 318
    I would suggest going ahead and checking your valves and adjusting accordingly. You can also narrow down the location of the sound using a stethoscope.
