Had some previous issues, vacuum leaks, leaking injectors. Fixed those problems, car has never run better. Now its time to fix the one last problem, low idle.
When cold, idles 500-600rpm. if you blip the throttle, it comes down to about 300 for a second, but never stalls, goes right back to 500ish.
Once at operation temp, car idles dead on 750.
Keep in mind I have a smoke machine and it does not leak.
If you unplug the ICV, there is no change whatsoever.
I have another ICV, it actually makes the car idle even lower when warm, about 650, but still cold idles at 500.
Things I have replaced and or tested in the last week:
CTS, O2, Hose clamps, vacuum lines, FPR, Fuel Relay, 02 relay, main relay
Fuel Injectors, TB Gasket, VC Gasket
previous issues outlined in this thread:
