Coolant (lots!) in Exhaust
  • eurolife
    • Jan 2013
    • 128
    Do I recently picked up this '89 325ix 5 speed for a nice $500. I'm new to the m20 but not new to cars, so hopefully the m20 gurus can help.
    Only catch is, like the title states, coolant is FLOWING out of the exhaust. PO is a certified mechanic and has replaced the head and head gasket. After replacing both, the car was fine for about 150 miles or so before the issue returned.
    Any suggestions on what it maybe? I'm hoping the block isnt cracked, but I'm leaning this way since the issue returned after a near new head and new head gasket were installed.
    The only other thing coming to mind is improper block or head resurfacing before the new head gasket was installed, or the some other issue I may be over looking.
    Thanks in advance guys!
  • Bmwb
    • Jan 2013
    • 196
    did the PO have proof of the replacement ? , people like to spice up a few things to sell a car ?
    Sold Black BMW E30 325IS
    1987 bmw e30 euro part out
    1990 Bmw 325i Cabrio 2.9
    Metric Mechanic 2.9 stroker
    Holset Hx35w CXRacing Manifold
    MegaSquirt ARP HeadStuds
    OEM HG AEM Methanol injection
    20psi
    • eurolife
      • Jan 2013
      • 128
      Definitely have this a thought. He is a coworker of my cousins, and my cousin has said he's trust worthy. I guess I trust him because of the multiple conversations I've had with him too.
      Also, selling it for $500 would be taking huge hit even if the entire motor had to be replaced, wouldn't it?
        Was the replacement head checked for cracks and surfaced before installation and the block checked for warp. The block is hardly ever the problem, but at the minimum a used head must be checked for cracks and almost always has warp.
        • DÃŒEGØ
          • 690
          Coolant system pressure tester. Use it.
          Driving:1990 325iS, 2007 335i :devil:
          past BMWs: 1987 325iS turbo, 1989 325i, 1995 525i, 2000 328CI, 2001 540i, 2008 135i
          • AndrewBird
            The Mad Scientist
            • 11898
            I'm having trouble wrapping my head around this problem.
            Lets say the headgasket is blown and is letting coolant leak into the cylinders. A small amount of coolant would just burn off and you would have a steamy exhaust. The only way coolant would run out the exhaust is if there was a LOT of it, and if there was, the engine would likely just hydrolock.
            Maybe I'm envision more coolant then is actually there. How much (in ounces or cups or some other measure of volume) is coming out of the exhaust?
            • eurolife
              • Jan 2013
              • 128
              A LOT of coolant. We didn't notice it being that much until it stopped running (probably hydrolocking) and found a puddle in the snow under the exhaust. Also a ton more came out while putting it in the tow truck to get it home.
              It's got me scratching my head a bit too
              • brianao34
                • Jun 2010
                • 660
                Worst case scenario, M20's are stupid cheap.
                • bmw325csi
                  • May 2007
                  • 4045
                  No shit, You got that car for 500 bucks?
                  I say you just look for another m20 for a few hundred and don't even waste your time trying to figure this out. In the end you will still have a pretty nice iX for under a grand.
                  harry/harout
                  • Bmwb
                    • Jan 2013
                    • 196
                    get yourself an m20b25 < drop that bish in and your set :p true the car was only for 500 bucks and e30s rocks sooo < do the swap or get an even better engine drop it in :p then you got yourself a project car!
                    20psi
                    • Holland
                      • Nov 2008
                      • 7212
                      Some of you need to remember that IX M20's have different blocks than I cars.
                      Originally posted by DEV0 E30
                      • Bmwb
                        • Jan 2013
                        • 196
                        ooo did not know that , so that is due to the all wheel drive well , cant u convert the car into just a rear , although keeping it allwheel is good , for alot of things but yea?
                        20psi
                        • Mr. Tasty
                          • Jul 2011
                          • 3421
                          no, there are differences in the block, not the transfer case/transmission.
                          2014 Alpine White 335i MSport
                          (Daily Driver)
                          Full Mperformance Aero
                          KW V2 Coilovers
                          VRSF Catless Downpipes
                            If coolant is leaking into a cylinder with an open valve, it will run out of the exhaust if the leak is large.
                            • brianao34
                              • Jun 2010
                              • 660
