Help identify oil leaks? (pics inside)
  • darkcolor.666
    • Jan 2013
    • 140
    hi all, i just recently picked up a e30, been fixing little things here and there, and i have noticed there is a leak in my driveway. i parked it in my garage to try identify where the leak is coming from.
    see attached pics. anyone with experience can identify what is leaking? sorry i know they are not the best pics. its basically the RED BOX area that i see is leaking...
    on a different note, how does my engine bay look? anything out of the ordinary?
    thanks in advance!
  • 5Toes
    • 9836
    Looks like headgasket or valve cover gasket, I would just deal with it if it is the headgasket.
    If its leaking BELOW exhaust manifold its headgasket, if it is above, then valve cover
    Bay looks clean
    • dnguyen1963
      • Nov 2011
      • 2648
      Looks to me like the leaks are coming from your valve cover gasket then drip down to the area that you drew a rectangle. Your heat shield is completely soaked with oil.
      • darkcolor.666
        • Jan 2013
        • 140
        Bay looks clean
        Thanks. Stupid question, how do I identify if my e30 using r12 or r134a ac? R134a is the modern setup right?
        • ButtJuice
          • Dec 2009
          • 2609
          Where are the other areas that leak beside the valve and head gaskets? I have a leak and it's annoying, I have to top off every other week. Castro's did my head/gasket so I hope it isn't that.
          1991 318is - Sold
          1986 325 - Sold
          Instagram - Lamoursum
          • Raxe
            • 5346
            The coolant drain plug for the block is in that area right under the exhaust manifold, worth checking that it's not leaking.
            Front/rear main seals, neither are easy to see and both can leak for a while before being detected. If you're topping it up every other week without seeing any signs of leakage I'd be suspicious about oil consumption...
            • darkcolor.666
              • Jan 2013
              • 140
              Yeah for sure it's not leaking coolant, it's leaking oil for sure. My cardboard has oil spots and trails
              • ButtJuice
                • Dec 2009
                • 2609
                Oh, I see leakage on the pavement for sure.
                Just out of curiosity, what causes an engine to burn oil?
                1991 318is - Sold
                1986 325 - Sold
                • Raxe
                  • 5346
                  Blow-by, worn rings and/or worn intake valve guide seals on higher mileage engines. Using too thin of an oil in an M20 won't help anything either, use 20W50 if you aren't already.
                  • Stanley Rockafella
                    • Aug 2011
                    • 4056
                    15w40 is good too
                    • ButtJuice
                      • Dec 2009
                      • 2609
                      I've been using 10w40, I'll switch in the next oil change. My block has 250k miles on it under the 'refurbished' castro head, I suppose I should look into getting that rebuilt as well. I haven't had any other major problems besides the oil loss.
                      1991 318is - Sold
                      1986 325 - Sold
                      • darkcolor.666
                        • Jan 2013
                        • 140
                        Originally posted by Stanley Rockafella
                        15w40 is good too
                        I used 10w40 this weekend. California weather.
                        • mcaden
                          • Jun 2011
                          • 164
                          I would start simple and inexpensive by replacing your valve cover gasket and the 4 rubber blind/rocker plugs the frequently leak. The VCG should be about $15 and the blind plugs are like $1.50 each. Then spray down the entire area with a degreaser and look for leaks. Good luck.
                          • darkcolor.666
                            • Jan 2013
                            • 140
                            Where do I find this for $15?
                            After using degreaser do I need to wash it down with water? Can I do the same for underneath the car to do a simple cleanup?
                            • mcaden
                              • Jun 2011
                              • 164
                              You can get a VCG (and the blind plugs) from your local BMW dealer or try an online place like Pelican Parts. It should take under an hour to replace.
                              See: http://www.pelicanparts.com/bmw/cata..._pg1.htm#item0
                              As for degreasing:
                              (1) warm your engine a little
                              (2) spray lots of something like purple power or simple green all over the oily spots
                              (3) use a scrub brush as needed
                              (4) hose down (try avoid spraying electrical components or simply cover them with saran wrap)
                              (5) repeat as necessary until clean
                              EDIT: Rocker shaft plug part no: 11-33-1-264-519-M17 (you will need four of them)
                              see: http://www.pelicanparts.com/cgi-bin/...FILTER_TOOL=ON
                              Good luck.
