M20B25 oversized pistons & rings
  • dwight
    • Dec 2012
    • 550
    Looking to buy the above new anyone no the best place to buy them
    Thanks
  • SkiFree
    • Jun 2011
    • 2766
    need more information. "best" is a moving target depending on what you are looking.
    Forged or Cast?
    Cheap or Extravagant?
    Intended use?
    ADAMS Autosport
      MaxSil pistons are good and a bit less expensive than the OE parts.
      • dwight
        • Dec 2012
        • 550
        Hi Jim I tried contacting them is it possible they do not have over sized pistons for the M20 B25 say 86 mm The fellow I spoke with told me they only offer 84.5 which is basically stock. I also like their brand just having problems finding them
        Thanks
        OK i finally spoke with someone at MAXSIL and they have what I need
          Don't forget to gap the rings when you assemble the engine.
          • dwight
            • Dec 2012
            • 550
            I'm going to have a machine shop build the whole motor so I hope they know to do that LOL Thanks Jim
            • nyChris
              • Apr 2012
              • 395
              I dont know what your price range is, but I picked up a set of CPs from VAC. A bit expensive, but worth it imo.
              85mm would probably be your best bet. From what I can tell by measuring the block 86mm may be pushing it. However I dont have any solid info to back up that last statement.
              For BMW M20B25 engine Bore Size: 84 mm; 84.5 mm; 85 mm. Compression Ratio: 8.5:1; 8.8:1; 10.25:1; 10.5:1; 11.25:1; 12.0:1.
              • dwight
                • Dec 2012
                • 550
                Hey Chris thanks for the introduction I called them up and talked with Steve very knowledgeable told him what I wanted and he's going to send everything with prices.
                Thanks Again
                Dwight
                  • 37829
                  Or buy the Ross pistons from Ireland Engineering and save almost $200.
                  Classic BMW Specialists
                  Grover Beach, CA
                  www.BimmerHeads.com
