So thanks to PennDot and Bucks County, an E30 still needs to pass pretty tight emissions standards here.
This exact same car passed the same emissions test at the same location with flying colors last year. Nothing has changed except I just had the car off the road a few months while I did some bodywork in the rear and rebuilt the suspension.
Motor is a 2.8 stroker with a 298* Cat Cam and it's running a Miller MAF, but not the WAR chip. It does have a cat converter that was new for last year's inspection (Magnaflow 2.5" generic).
Just today, it failed by a LONG shot in all three categories: CO, HC, and NO.
The strangest part in my mind is that the car runs great! It has never pulled as smoothly and as hard as it does since I got it back on the road again last week. It will break loose in second by just easing into the throttle at 4k RPM, haha. Wouldn't do that before.
My inspection mechanic who is not a foreign car guy told me I should check the timing. That doesn't make sense in my mind, nothing has been altered, not to mention the ignition timing is not adjustable manually correct? Plus the crank to cam timing is normally not adjustable (though I do have an adjustable pulley, it's currently set to 0*).
If you any suggestions, I'm happy to hear them. Thanks!
