brake booster hose ??????
  • The Bimm
    • 135
    so on my 89 m20b25 that i just swapped into my 87 e it has two vacuum hose ports on the throttle body that mate with that check valve thing then goes down to the brake booster. i have seen some e30's with only 1 hose would it be okay to make it have only one hose if i have that other check valve? couse i don't have the intake boot that has the vacuum line that goes to one of those hoses.
  • vpilarrt
    • Jun 2006
    • 2096
    Yeah it'll work fine. You just have to plug the 2nd port on the rear side of the throttle body.
    • The Bimm
      • 135
      Cooool man thank you
