Help! M20b27 rough idle and stalls/sputters
  • Znick742
    • Feb 2013
    • 129
    I have a serious problem with me e30 that's really starting to piss me off. It has a low rough idle an then it will shoot back up to 900 then back down. If I blip the throttle to wot the idle will come back down really low and almost stall for about 25sec then go back up. Randomly about once a day the car will sputter and die and won't run. I have to crank it about 10 times before it will run again. And the whole time I'm cranking it it will smoke really bad like a light grey color.ive replaced the afm,iacv,and tps but its still doing it. Any help would be greatly appreciated.
    Current car-86 325e never ending project
    You only get out as much as you put into it
  • Bimmer_man
    • Jan 2013
    • 1478
    Could be a number of things my car did the same but I put race fuel in it like a moron and it would do that my issue kinda fixed itself. If I had to make some suggestions try replacing your catalytic converter it may be clogged or something. Or try cleaning your fuel system and replacing your fuel filter. Just my 2 cents.
    Float like a cadillac sting like a Bimmer!:)
      Idle or hard starting problems are most commonly caused by intake leaks and/or
      a sticky or defective Idle Control Valve (ICV). The only reliable method of
      locating intake leaks is to have a smoke test run on the intake and crank case
      and to test the brake booster with a gage and vacuum pump. The complete list
      of possible causes of an intake leak is:
      Intake boot
      Throttle body gasket
      ICV hoses & connections
      Brake booster, hoses, and connections
      Crank case breather hose
      Evaporative control hoses, valve, and expansion tank
      Fuel pressure regulator & hose
      Injector seals
      Valve cover gaskets & bungs
      Oil filler cap
      Dip stick o-rings
      Oil return tube o-rings
      While leaks in some of those can be found by inspection or by spraying carb
      cleaner on suspect areas, not finding leaks that way doesn't eliminate the
      possibility. Only a smoke test will really work.
      Once the possibility of intake leaks is eliminated, the ICV needs to be
      removed and cleaned with carb cleaner until the vane inside moves freely. When
      the ignition is switched on you should be able to feel vibration from the
      ICV. If no vibration the ICV is bad, there's a problem with its wiring or
      connector, there's a problem with the TPS, or the DME (or Idle Control Module
      (ICM) on an ETA car) is faulty.
      For the DME (or ICM) to control idle, the idle switch in the TPS must work
      correctly. The switch should close when the throttle stop is 0.030-0.060" off
      the idle stop screw. Hearing a click doesn't mean the TPS is working. Check
      with a meter or test light.
      The fuel system should be tested via the suite of tests in the Bentley manual
      as invalid rail pressure can be a contributor to idle and starting problems. A
      simple injector check is to pull the injectors, jumper the fuel relay to run
      the pump, and see if the injectors are leaking. You can also point the
      injectors into a towel, remove the coil wire, and crank the engine to see if
      all of the injectors appear to be spraying in a similar fashion. The best
      approach to possible injector problems is to have the injectors cleaned and
      flow tested. Since raw fuel can or will be released in these tests, have a
      fire extinguisher handy.
      While a bad check valve in the high pressure pump can result in longer than
      normal cranking, if the fuel system is working as it is supposed to the rail
      will reach normal pressure in a few turns of the engine. A weak pump, clogged
      filter or leaking FPR in conjunction with a failed check valve can result in
      longer cranking and/or idle poroblems.
      The O2 sensor can be a contributor to idle problems. The O2 sensor is a
      scheduled maintenance item with a useful life of no more than 100k. If the
      sensor has that mileage or more (or is of unknown age), replace it.
      The AFM can be a contributor. If the vane doesn't move freely or the
      resistance track is worn the DME may be receiving invalid data from the
      AFM. And if someone has fiddled with the bypass air adjustment the DME may be
      unable to stabilize idle. The bypass air adjustment should only be adjusted
      per the procedure in the Bentley and with an exhaust gas analyzer. And even
      then everything else associated with engine management has to first be
      operating properly. If the AFM becomes a suspect, replacement with a good used
      unit is the best approach.
      Improperly adjusted or malfunctioning valves will affect idle and starting. As
      can compression issues from ring or cylinder wear. A valve adjustment is
      called for every 15k. A useful diagnostic is to run compression (dry and wet)
      and leak down tests on the engine. Aged ignition wires, plugs, distributor
      cap, or rotor can cause problems. Insulation does break down with time and
      heat. And since the youngest E30 is going on 20 years old, if the ignition
      system is original or the plugs are old replacement is indicated.
      Although not usually a problem, a bad DME temp sensor is a possibility. That
      generally won't cause an unstable idle, but can cause hard cold or hard hot
      starts and/or a rough idle. As can problems with the timing reference
      sensors. Although not commonly encountered, a bad harmonic balancer on an
      M20B25 or M30 engine will cause problems.
      When all other possibilities have been eliminated and idle or starting
      problems persist, replacement of the DME, or if applicable the ICM, is
      indicated.
      In many cases the cause of problems will be a combination of factors. So it is
      important to test and repair all of the possible causes.
      • Znick742
        • Feb 2013
        • 129
        Yeah I was thinking my fuel filter but I hooked a fuel gauge up to the car and it was at what it was supposed to be the whole time.
        • Znick742
          • Feb 2013
          • 129
          Intake boot
          Injector seals
          Oil filler cap
          Dip stick o-rings
          indicated.
          Awesome information thank you. I checked the fuel system and its strong no problems there. I replaced the afm. I'm going to try and adjust the tps right now cause I'm not sure if its adjusted right. I switched out the icv today for another one and its running a little better it hasn't stalled yet just the idle drops down to about 600 sometimes still. I have a vacuum gauge and it shows good vacuum
          Except when it drops down to 600rpm then vacuum reads low. Compression on the motor is great, I checked that. Plugs and plug wires are new,new distributor cap. The 02 sensor is new also. So after replacing the icv it does run a little better but still has a low idle sometimes and vacuum drops.
          • dnguyen1963
            • Nov 2011
            • 2651
            Vacuum drops mean you have a leak in your engine. Time for a smoke test.
