Solved
  • Nick's e30
    • Mar 2012
    • 676
    Solved
    Done.
    No antenna? I sell plugs!
    Here: https://www.r3vlimited.com/board/sho...77#post4937877
    Is it just the head of the bolts that are stripped? A biting type nut/bolt removal socket should get them out if it is just the heads.
    • E30stan
      • 658
      this kind
      http://www.sears.com/craftsman-10-pc...1&blockType=G1
      • tinkerputzer
        • Jun 2008
        • 508
        iirc those are 13mm not 14mm. Might be why you are having troubles. Also i use 6 point sockets as 12 point are less reliable on stuborn fasteners.
        • AndrewBird
          The Mad Scientist
          • 11898
          Originally posted by E30stan
          I have this set and they have saved me a few times. Once while removing the nuts off the exhaust union on an M42. They grabbed hard enough I was able to break the rusted bolts off. Didn't slip once.
