16 MPG? Suggestions?
  • BROKINBIMMER
    • Nov 2012
    • 195
    Okay, so I have read many many threads on here about what to replace for optimal fuel mileage. I am not sure what else to replace/check to fix this issue. So far I have replaced plugs, cap, rotor, fuel pump, fuel filter, air filter, head gasket, coolant temp sensor, cleaned the MAF, and I'm sure I'm forgetting some parts.
    What else should I replace/check? Valve adjustment? Plug wires? FPR? Any suggestions and or pointers would be appreciated.
    Cliff notes
    stock M20
    Auto trans
    200k miles/rebuilt head
    16 mpg mixed driving
    Fresh tune up
    I drive with a light foot
    Tires fully inflated
    Stock rear diff
  • evandael
    • Oct 2009
    • 2881
    dragging brakes, old hub bearings, gummed up injectors, bad O2 sensor, valves need to be adjusted, timing is off a tooth..
    • ELVA164
      • 4861
      I'm assuming it's an M20B25? I would check for vacuum leaks by getting a smoke test done or at the least inspecting the lines for hardness or cracking. If you haven't adjusted the valves in a while that should be done anyway, and I would see if any PO's have messed with the AFM or not. Also, the automatic trans will hurt mileage a little but doesn't account for all of that.
      • bmw325csi
        • May 2007
        • 4045
        Sorry to thread jack but I'm in the same boat. Would a maf affect mpg's.
        I'm subscribing to this thread because I need yo up my mpg's also
        harry/harout
        • BROKINBIMMER
          • Nov 2012
          • 195
          Thanks guys. Yea, it's an m20b25
          Other new parts:
          New o2 sensor
          New cat converter
          Bought this thing for cheap commuting, and so far it's been anything but...
          • BROKINBIMMER
            • Nov 2012
            • 195
            Should the FPR be suspect? I'm assuming at this point it has to be running rich...
            • kingston
              • Jun 2010
              • 2669
              Yes it would.
              Originally posted by LJ851
              kingston is the play by play announcer for this thread.
              ‘Tis by the grace of God that my cars run!
              Originally posted by unloadedak
              #teamross
              Siobhan's Build Thread - UPDATED!
              • BROKINBIMMER
                • Nov 2012
                • 195
                Originally posted by kingston
                Yes it would.
                How would one test a MAF? I can certainly solvent clean it again, or would buying a new one be the way to go?
                • bmw325csi
                  • May 2007
                  • 4045
                  You have an air flow meter though don't you? Clean it with some carburetor cleaner. Take of you air box, run the car and spray some in whole revving.
                  I ment I actually changed my afm to a maf sensor. It's works fine but will that upgrade affect mpg's ?
                  harry/harout
                  • Rockwool2117
                    • Jan 2013
                    • 143
                    Try the M10 :up:
                    The day I bought my e30, was the day I became sophisticated and classy as fuck.
                    • BROKINBIMMER
                      • Nov 2012
                      • 195
                      Mine is bone stock...so I should take apart and clean the air flow meter?
                      • bastianshaw
                        • Jan 2007
                        • 2210
                        your problem is you think you should be getting better mileage
                        • BROKINBIMMER
                          • Nov 2012
                          • 195
                          This has me. Thinking....Although I am very hesitant to mess with the AFM. Shoul I try adjusting the screw to lean her out a bit?
                          • ELVA164
                            • 4861
                            I wouldn't mess with the AFM yourself unless you know what you're doing. Did you pull the spark plugs to check the mixture?
                            • BROKINBIMMER
                              • Nov 2012
                              • 195
                              So u guys think its unlikely not the FPR?
