Where do I start,
Was running a boosted m20 but blew it up, can't afford to fix it right now so I swapped in a known good stock motor
I'm getting a rich stutter that happens in all driving conditions (idle, cruise, accel, and deccel) doesn't matter if the car is warm or cold, though it seems to happen more often when cold.
So far I've replaced injectors with m50s do to the stockers making the motor excessively lean (had af gauge hooked up and was reading 18afrs on acceleration..
Replaced the cps with a clean, known good one. No fix
Changed out cap and rotor with a good one. Seemed to clean up my idle a bit but still now fix
New o2 sensor. No fix
Fuel filter is new
Thermostat is a 75 degree but I don't feel like it would be a problem
Only thing not hooked up is the charcoal canisters but don't think that would be a problem either because I thought those where just a emissions thing. Either way the sensor that goes from the hose off the bottom of the tb to the charcoal canister is hooked up.
Need some input because this 13mpg is killing me lol got better mpgs when I was boosted with 60lbers
Fuel filter is new
