adjusting valves
  • e34_spangler
    • Dec 2012
    • 311
    adjusting valves
    well i'm going to adjust the valves and two of the valve eccentric spun on me and now theres no whole to adjust it! wtf! i adjust the rest but these two moved on me now what do i do!? its got me abit worried
  • Mr. Burns
    • Aug 2011
    • 3516
    they just rolled back and have now somehow tightened themselves?
    Originally posted by flyboyx
    i have watched my dog lick himself off a few times
    • e34_spangler
      • Dec 2012
      • 311
      No not tightened I read that its cause I dont have it in tdc but the camshaft seems to be where there supposed to but then again this is my first time doing this
      Sent from my SCH-I535 using Tapatalk 2
      • e34_spangler
        • Dec 2012
        • 311
        ok so i think i figured it out when i move the car it moves the camshaft and you can adjust certain ones so when i move the car back and forth the feeler seems good on all of them does that mean i did it right?
        • lambo
          Captain Scene Points
          • 10953
          You're supposed to, in one way or another, make the crank move so that the piston of whichever cylinder you're working on is at TDC. Then you adjust the valves.
          Pelican has a nice guide: http://www.pelicanparts.com/bmw/tech...lve_Adjust.htm
          • MoreMayhem
            • Feb 2012
            • 650
            you are moving the car back and forth to turn the camshaft?
            I've learned something new! I've always taken the spark plugs out and turned the crankshaft from the bolt on the front of the vibration damper.
            • dnguyen1963
              • Nov 2011
              • 2651
              Or jack up the rear wheel, pop the gear into 5th, remove the spark plugs, rotate the wheel to locate TDC. Bavauto sells a little whistler that you can plug into the spark plug hole. TDC is when the thing stop whistling.
              • e34_spangler
                • Dec 2012
                • 311
                Yeah but any ways I didnt feel like waiting for some one to tell me if I did it right haha and I started her up everything is great!
