could someone?
  • e30construction
    • Jan 2013
    • 591
    could someone?
    could someone point me in the direction of a valve adjustment diy..and yes i searched "valve adjustment" in the diy and nothing came up so if anyone could i appreciate it alot thanks
    93 325i 120k
    mods: straight pipe,eibach sport springs,style 54s,kamotors carbonfiber cai,
    future mods: chip, m3 cams, headers, turbo
  • karmatose
    • Sep 2011
    • 114
    Here you go.
    "She may not look like much, but she's got it where it counts, kid. I've made a lot of special modifications myself. " - Han Solo
    • e30construction
      • Jan 2013
      • 591
      thanks man looks great..now i just gotta DO it lol..im pretty good at these kinda things i just wanna do it right..any tricks that the website doesnt cover when doing it? everywhere ive read ppl say its pretty easy but i talked to a person at oreilys with the same car as me and he said its a pain in the a**
      93 325i 120k
      • TurboJake
        • 3780
        The person at O'reilly's needs to get a different job.
        Leave Me Transaction Feedback
        • e30construction
          • Jan 2013
          • 591
          the website doesnt say what size feeler gauge but another did i just wanna make sure..the other site said .25mm (0.010in) for a cold engine is this correct and what would you guys recommend?
          93 325i 120k
          • Farwest92
            • Jul 2011
            • 192
            Yes, between the adjustment cam and valve top. I suggest a scratch pad with the numbers 1 through 6, intake and exhaust and mark each valve as you make progress. Turn the crank with a 22mm wrench and work your way through it. Then go back and check each one again. Loose is better than tight when sliding the feeler gauge.
            Just remember that this is supposed to be fun.
            • e30construction
              • Jan 2013
              • 591
              can you turn the crank by hand or by rolling the car? and where is the bolt to turn it by a wrench? and so im gonna be adjusting 12 altogether?
              93 325i 120k
              • Holland
                • Nov 2008
                • 7212
                Be slow and thorough and you will find it's easy and simple. Rushing will only end up making you do it twice.
                Originally posted by DEV0 E30
                • lambo
                  Captain Scene Points
                  • 10953
                  http://www.pelicanparts.com/bmw/tech...lve_Adjust.htm
                  • ELVA164
                    • 4861
                    You can put the car in gear and push it (the higher the gear, the less movement required to turn the motor), but it's a simpler process to use a wrench. The bolt is on the front of the motor near the bottom, maybe 3/4 of the way down. And it's true that loose is better than tight, but aim for the feeler gauge to move in and out with a little bit of resistance. You don't want it to slide in and out easily, nor do you want to have to shove it in and out.
                    It's a cinch once you get the hang of it!
                    • e30construction
                      • Jan 2013
                      • 591
                      so when doing this the lobe thats beside each rocker is the one that needs to be facing down? and do you leaves it down to change the exhaust and intake valve
                      93 325i 120k
                      • ADlBOO
                        • 335
                        The lobe under the rocker your adjusting. And you have to move the crank for each valve/rocker your setting.
                        I have friends who are EOD bro.
                        That's awesome. I have friends who make coffee for a living, but you don't see me rocking out a bunch of lattes
                        • Timmyboy
                          • Jan 2013
                          • 99
                          if your looking down on it you have the springs, and the rocker arm touches them. The back side of the rocker arm is above the lobes. Using a 22mm wrench on the crank bolt with the car in neutral you start at cylinder 1(closestto fan) and find TDC. TDC is when the lobes( exhaust and intake) point downard. They dont have to be EXACTLY downward, just facing that way to relieve pressure off the springs. Loosen the 10mm bolt on the rocker arm/eccentric and using a small alen key or wire move the eccentric while having your feeler gauge between the rocker and spring and from then you can get the point.
                          DOUBLE AND TRIPLE CHECK.
                          • e30construction
                            • Jan 2013
                            • 591
                            so when you have the lobe positioned down to do the first valve cant you go straight across to do that one since its on the same lobe?or is there different lobes for each individual rocker?
                            93 325i 120k
                            • e30construction
                              • Jan 2013
                              • 591
                              found a pic im guessing theres a lobe for each rocker but on the pic the 2 lobes beside each other are facing the same way so shouldnt you be able to adjust both rockers since the lobes are both facing down?
                              93 325i 120k
