UPDATE: pulled the plug wires while it was running and it didnt do anything in 4 cylinders but all the plug wires have spark. spark at the wrong time?
Well...my car took a shit on me. I've owned it for a few months now and once every 2 weeks or so the car would randomly start running rich and misfiring and wanted to die. Then out of no where it would run great again. It would happen hot or cold. It was hard to diagnose because it would fix itself. Well just a couple days ago I went to start it and it was acting up like usual so I drove it around hoping it would fix itself....it didn't. Now it rarely starts and when it does it runs stupid rich,misses and sputters when you give it gas, doesn't want to idle. When I was driving it it would sputter when I give it gas then once engine rpms got higher(3k) it would pull hard then loose power toward the top end.
Things I've done:
Pulled the plugs and they were all black so I cleaned them up
Check fuel pressure(its good)
Checked injectors(working correctly)
New dizzy cap
New spark plug wires
Different afm
New fuel pressure regulator
Newer tps
Known good ecu
Timing is spot on
Newer 02 sensor
All engine grounds are solid
No vacuum leaks
This car straight pissing me off I can't figure it out its a mystery problem that can't be solved. But I thought I would post this to see if anyone has ever had these symptoms.it seems to me it's not getting enough spark but when I pull the plugs while its running its getting spark.
I appreciate all the help I can get.
Things I've done:
New dizzy cap
Different afm
Newer tps
Known good ecu
Timing is spot on
Newer 02 sensor
No vacuum leaks
