so I finished up the 327i build for my friend, before I slap the turbo on I want to get everything squared away mechanically, so I went to start it today and it cranks over nicely, gets good oil pressure quickly, but is NOT getting fuel and also Tunerstudio is showing the ECU as not connected.
I've replaced the 3 relays out and still no fuel or ECU signal. Am I missing something that is needed when doing a 325i head swap on an 85e?I made my own harness from fuse box to engine harness and it went very smooth and 90% of colors matched right up from the 1987 I harness to the 85e fuse box harness.
I'll update with some pics tomorrow of questionable things on the harness I have. There is a thicker yellow and black wire that is capped off near the ECU and I'm not sure if its stock and also all the power wires to the power distribution block are put in to one large connector by previous owner.
the little plugs in the glove box are all disconnected for now but i hear the car will still start without them.
