head question
  • WI.E30M.S.
    • Mar 2013
    • 2
    head question
    I am having a problem assembling my head I cant get the rockers on the rocker shafts with the valves and cam in. any tips?
  • E30_fiend
    • Apr 2006
    • 7348
    You cant just simply put the rockers on the shafts while pushing them through. You will have to rotate the cam to a flat part of the lobe starting at cylinder #1 and rotate the cam as you push the rods through. Put cylinder #1 at TDC on the cam and install the intake and exhaust rockers for that cylinder then move to cyhlinder #2 doing the same thing I just said,
    Good luck!! Should be a breeze
    • WI.E30M.S.
      • Mar 2013
      • 2
      it makes it a little easier when you put the rocker shafts in from the side opposite the cam pully and use the pully to rotate the cam. then the shafts don't get in the way. I promise im not handicap sorry to waste your time.
