Custom Stroker pistons?
  • deansbimmer
    • 674
    I'm trying to find a good set of 2.8 pistons for my stroker. Is there a preffered set for this setup? What information would I need to supply the shop if I wanted to order a set? Stroke, bore, compression, etc., or if I said 2.8 stroker 10.1:1 would they know exactly what I need? Might as well ask, this is one of the last things on my list. Thanks.
  • Jordan
    • 12916
    You need to call a custom piston maker and tell them what you need.
    2.8L stroker isn't going to be one of the things you tell them that helps.
    bore
    stroke
    conrod length
    what head/engine
    desired compression
    I would recommend NOT going to JE Forged Pistons.
    https://mtechniqueabs.com/
    • deansbimmer
      • 674
      Thanks for the info.
      • Mike B.
        • Jan 2006
        • 987
        What type of problems have you had with JE? I'm curious because I've used them in Porsche 911 rebuilds and the quality has been excellent.
        • AndrewBird
          The Mad Scientist
          • 11898
          Explanation:
          • DrMcDave
            • 1793
            if you want to say 2.8 stroker and get pistons call metric mechanic.
            • Jordan
              • 12916
              Everything from MM is way overpriced compared to what you can source all on your own.
              • Mike B.
                • Jan 2006
                • 987
                I had a similar deal with Top End Performance and TWM Throttles recently. It took 6 weeks to get a set of throttles made up for one of my customers and then they shipped it to the wrong address! It sucks being at the mercy of your suppliers.
                I have, however, had good luck dealing with JE directly. We are a dealer for their pistons (primarily Porsche) and have had good experiences so far. That being said I know a lot of people who won't use their pistons. Their reasons are well justified and have had experiences just like Jordan's. At least there are other options out there to make everyone happy.
                • Mike B.
                  • Jan 2006
                  • 987
                  Jordan,
                  What manufacturer/source do you recommend for pistons?
                  • Jordan
                    • 12916
                    Ross, Wiseco, or Alusil are easily just as good. Pretty much everyone is going to be using the same hardware on the tooling side these days.
                    • DrMcDave
                      • 1793
                      i know but you can literally call and say that and get what you want.
