I swapped an M20B25 into my 87 eta car in prep for this rallycross season. The season starts SUNDAY with a test & tune tomorroew. As of now...not looking good.
This post will be long- I want all of the info out there.
Current situation:
After several days of letting it run (now that the cooling system is installed and bled), the car starts up fairly well but idling is a little rough. Not terrible, but not great. It stumbles badly when I put it under load and it has absolutley no power. It feels worse than the eta motor, and I could barely get it to stay running long enough to pull it into the garage on Wednesday to put it up on the lift to do the exhaust. I don't have a working tach right now but it does not feel like it is revving very hard or very far.
Backstory:
I FINALLY got in the missing CCV hose last night and had high hopes that the stumbling under throttle woudl be resolved. No such luck. I am pretty much at my wits end here.
Diagnostics/ Trial & Error:
Here is what all I have tried, as well as the result:
Pretty much down to the piss-poor diagnostic concept of replacing intake/sensor/fuel parts 1 at a time to checking for a change. Looking first at the AFM, ICV, TPS...easy stuff.
I plan to try to check injector function after work, and then to check that the spark plug wires are on the car in the proper order. Another suggestion to check is fuel pressure, but I don't have a FP gauge. There is a chance that the fuel pump was damaged or simply died during the swap process (or that the heat from the welding/install of my roll cage somehow damaged it), but I can't SEE any damage and it is at least partially functional.
Where should I go next with diagnostics?
Current situation:
Backstory:
- B27 had a bad oil leak so we swapped it out.
- THe B27 was fully functional, but...
- The external fuel pump was LOUD at times. Functional, but loud.
- B25 was bought from a R3v member who was doing an M50 swap. I was initially under the impression that he had built the motor, but I came to find out that he bought it from someone who had refreshed it. The motor looked really clean, but I started to find a LOT of RTV on things...particularly intake/vacuum hoses in the TB. It was also missing the CCV hose (VC to TB)- more on that later.
- I was also told that the motor was stock, the timing had been set, and the valves were adjusted. HAVE NOT VERIFIED ANY OF THIS.
- I am on a stock 173 DME.
- The exhaust was removed to go to a single 2.5" exhaust w/o a cat (car is track/rallycross ONLY and is towed to events). Re-installation of the exhaust is still ongoing as of the time of this post.
- Right after the swap, we started it up and had a C101 issue due to the presence of airbag wiring, but that was resolved.
- I had an early model radiator and a late model water pump, so I had to run the car sparingly when we first fired it up.
- Gauge cluster was always somewhat irregular in the eta, but after swapping in the 2.5 the gaiges seem to be very erratic. Temp gauge is bouncy, fuel gauge seems right, tach not functional (a 7K tach was swapped into the eta cluster).
- Bypassed the ICV (sealed off both ports and used my foot or hand to hold throttle to replicate idle): Did not seem to make a difference.
- Installed the new CCV hose. No real change to the stumbling. Idle seemed to be better/worse from one startup to the next and had no consistency.
- Stomp test: no response (cluster is an 87 eta cluster with a swapped tach)
- Swapped DMEs for another stock 173: no change.
- Disconnected AFM: idle slowed, recovered.
- Reconnected AFM: idle slowed, recovered.
- Disconnected ICV: no change.
- Reconnected ICV: idle slowed, recovered.
- Removed speark plug wires: Each time the motor stumbled and recovered, but on the front one removal caused a stall every time I disconnected it.
