Hard, long crank start when cold, warm. m20b25
  • nickmcc92
    • Dec 2012
    • 442
    I've been having this problem ever since I replaced my fuel filter and fuel pump gasket.
    Before I touched it it would crank 2-3 times then start. Now it never starts first try after 15+ min. Any time longer than an hour it will start, then stumble like its going to die. Unless I gas it.
    Been reading it could be fpr, constant pressure valve, leaking injectors, fuel pump.
    Anybody with same problem w/ solution? Or troubleshooting tests?
    I have only basic tools and no money to buy anything. $0
  • e30construction
    • Jan 2013
    • 591
    make sure you didnt leave anything loose when installing the filter..there might be air seeping in from somewhere..i wld recomend double checking everything that u messed with..also did u disconnect the battery?
    93 325i 120k
    mods: straight pipe,eibach sport springs,style 54s,kamotors carbonfiber cai,
    future mods: chip, m3 cams, headers, turbo
    • nickmcc92
      • Dec 2012
      • 442
      Battery disconnected. I also put back the old filter and still have same problem.
      • nickmcc92
        • Dec 2012
        • 442
        I've also replaced fuel pump relay
        • nickmcc92
          • Dec 2012
          • 442
          I might try this external check valve kit
          Part Number: 16-14-9-068-988
          And come back with results
          • dnguyen1963
            • Nov 2011
            • 2648
            Hard starting, starts then dies, and rough idles are signs of vacuum leaks.
            • e30construction
              • Jan 2013
              • 591
              well yes to vacuum leaks but since you disconnected the battery you may not have given the dme time to restore itself..when i disconnect my battery i have to drive it for a little while and when i push the clutch in and what not itll try to die untill it restores idle..best thing to do is drive it to an empty parking lot and rev it and then let it drop and try to fix itself..and do this a couple times and u should start noticing a difference and at some point itll fix itself
              93 325i 120k
              • nickmcc92
                • Dec 2012
                • 442
                Neither vacuum leak or ecu reboot.
                I replaced it three months ago.
                • dnguyen1963
                  • Nov 2011
                  • 2648
                  Go again...how did you take care of vacuum leaks?
                  • nickmcc92
                    • Dec 2012
                    • 442
                    I put on the old fuel filter. Now my car starts up first try but still takes about 5 cranks to start.
                    I've changed my intake boot and my idle isn't rough.
                    • dnguyen1963
                      • Nov 2011
                      • 2648
                      There are many other places that contribute to intake leaks; thus, hard starting.
                      • nickmcc92
                        • Dec 2012
                        • 442
                        I think I got it! I forgot I stripped 2 of my valve cover studs. Could this be the intake leak? My idle also flunctuates slightly in park but not on drive.
                        • e30construction
                          • Jan 2013
                          • 591
                          yes that could def be it..a vacuum leak there would cause bad starting/rough idle..wld def recomend getting that fixed
                          93 325i 120k
                          • nickmcc92
                            • Dec 2012
                            • 442
                            What other things cause a long start?
                            • dnguyen1963
                              • Nov 2011
                              • 2648
                              Beside vacuum leaks, a bad signal from CPS can cause a non-start. Get a smoke test done ASAP.
