M20 Idling Badly
  • SFlan82
    • Mar 2013
    • 6
    M20 Idling Badly
    Hello. I am new to this site and new to BMWs. I have always wanted to get an E30 because I like the way they look and the way they sound. I finally got the chance to get a 1990 325i for $1300, and I jumped on it. It has some issues, and I have already put a lot of work into it. I hope someone can enlighten me on this last problem I am having.
    The engine idles very badly. Sounds like it's running on 4 cylinders. The idle is also erratic. The erratic idle clears up when the car warms up, and the misfiring doesn't seem as bad, but it's still there. The car fires right up in the morning, or if it has been sitting for a couple hours, but if there isn't very much time between (like running in the post office for a minute) it's hard to start. Here's what I have done so far based on what the previous owner told me about the history of the car.
    New ICV
    New Intake Boot
    Valve Adjustment
    Air Filter
    Fuel Filter
    Plugs
    Wires
    Cap/Rotor
    Vacuum Lines Replaced
    O2 Sensor
    Adjust TPS
    The only vacuum line I haven't replaced is the one from the intake manifold to the valve cover. I will change that tomorrow. I have tested the ICV and found battery at the center terminal (when other end of the meter was on a chassis ground) and 9.3 volts between the center and one of the outer terminals. The other outer terminal only shows 4 volts. I tested the ICV connections at the DME for continuity and they are also in spec. When the engine is running, unplugging the ICV does nothing. Plugging it in makes the engine RPM go up for about 1/2 a second and then it keeps doing what is was before.
    I am trying to not just throw parts at it. The things I've done so far were preventative things were over due; I was just hoping they would fix the problem. I am not sure where to go from here. I am leaning toward leaking fuel injectors, because of the hard start condition. I also suspect the DME. Any insight you can give me would be awesome. I lost my job a while ago, and we're living on my wife's income while I finish school, so money is kind of tight. I'd like to tell her I need to get a part and it actually fixes the car. ;)
    The early bird gets the worm, but the second mouse gets the cheese.:)
  • SFlan82
    • Mar 2013
    • 6
    Took the breather hose off this evening. Someone cut the center out of it and stuck the two ends into a larger diameter hose. That's a recipe for disaster. I ordered the correct hose. Should be here by the end of the week.
      After you replace the frankenstein hose, have a shop run a smoke test to check for intake leaks.
      • Quinthirty
        • Mar 2012
        • 318
        Try cleaning the CPS and see if that works too.
        • SFlan82
          • Mar 2013
          • 6
          Thanks guys. I bought some intake manifold gaskets yesterday. I was contemplating whether or not I am motivated to change them. I probably will just do it.
          • SFlan82
            • Mar 2013
            • 6
            The new breather hose seemed to clear it up a LOT. Still got a little misfire type of sound to it, but it's 95% better. Got a new DME on eBay for $20. I was going to hook it up just to see what it does. I figured for the price it would be good to have an extra one around.
            • Stanley Rockafella
              • Aug 2011
              • 4062
              sounds like an average m20 to me
              • Dozyproductions
                • Jan 2007
                • 4682
                Would checking the exhaust gaskets be of any benefit?
                • SFlan82
                  • Mar 2013
                  • 6
                  Exhaust gaskets are new. Had to replace the entire exhaust system because it was rotted out. Doesn't have the tell tale tick of an exhaust manifold leak. I ran some SeaFoam through it today and smoke only came out the tailpipe so looks like the exhaust is leak free. I hooked up the new DME for S&G and it seems to have helped even more. I know it takes some time to "learn" so I'm happy with it. I'm bringing it to the body shop at school tomorrow so they can put it on the frame machine and yank it back straight from when it was hit.
