So for a while now my car has had hesitation issues. This has happened when I reach around 80mph or when I am at 90 - 100% throttle. On the way home my car started losing power and about 2 seconds later started backfiring. By losing power, I mean hitting the accelerator did barely anything except for causing more backfiring.
On the first backfire it shot out some bright glowing orange stuff... not sure what it was, but I immediately pulled over and turned off my car. I was a mile from my house and limped the car home. On the way back it would backfire over 25% throttle. Before all this happened, I was running low on gas earlier on in the day before work and was getting error code 1251. I then filled up my car after work with 91 octane since I have a dinan chip.
I'm going to check my spark plugs (which are new) tomorrow. But I have a new 02 sensor, plugs, distributor cap, CPS, fuel pump / filter and new coolant temp sensors (which is unrelated but just thinking of everything I've done recently).
Anyways, any thoughts on what the issue could be?
