Eta bottom I head wiring question
  • Kozworth
    • May 2011
    • 1339
    To swap the I head do I only need the injector harness that also contains the dlc, crank, oil sensor, alt hookup, starter hookup etc? Or do I have to swap the whole harness from the connector at the firewall that has the fusebox, harness running into under the dash, etc as well?
    Thanks
    • 37833
    You need the complete ENGINE harness. You don't need to change the body harness...
    Grover Beach, California
    BimmerHeads.com
