M20 running noise
  • mathillois
    • Sep 2012
    • 71
    M20 running noise
    Hey guys I was hoping if someone could help me with this issue my engine is making. Every time I rev below 3k whether its in gear or not it makes a rubbing noise on the right side of the engine. I checked oil levels and they all check out well. Please help
    Marc
    Check to see if the fan is rubbing on the shroud. Bad motor mounts can cause that.
    • mathillois
      • Sep 2012
      • 71
      What should I do to stop it?
      Replace the fan? Obviously the motor mounts which do need to be replaced.
      • dnguyen1963
        • Nov 2011
        • 2651
        You just answered your own question...replace the motor mount.
