m20 swap in a 318is NO START
  • nunezfrancisco30
    • Mar 2013
    • 94
    Hi guys, Im new to this forum, joined it becouse it seems as if this is a great place for help :)
    well the the tittle says it, a no start. I droped an m20 into the 318is before winter started... couple of months later and I still havent managed to get the dam thing started.
    things that have been done so far,
    checked all fuses-good
    relays-good
    computer-good(ive used several just to make sure)
    checked the entire wiring harness-good
    all of the grounds-good
    engine cranks, confirmed oil pressure.The pump doesnt turn on unless I jump the relays, no spark either. If someone could please help me out with any type of ideas as to why it wont start, i would really apreciate it. Im honestly running out of time, I need a working car and id hate to sell it, but i have no other choice if i cant get it to run soon.
  • dnguyen1963
    • Nov 2011
    • 2648
    For the car to start, it needs fuel, air, and spark. It looks like you have two...fuel + air. I would check the ignition coil next then make sure that the plug actually sparks when crank. Are you sure your dist/cap are ok? spark plug wires?
      For the engine to run the following conditions must be met:
      Power on DME pins:
      27 Start Input
      18 Un-switched Power input
      37 Power Input from Main Relay
      Ground on DME pins 2, 14, 19, 24
      Timing data from the CPS on DME pins 47 & 48 from a rotating engine
      To have spark power must be present at the coil positive and ground pulses
      from the DME's pin 1 must reach the coil negative. Power to the coil is
      controlled by the ignition switch via C101. When checking for spark, use the
      output lead from the coil to eliminate the distributor, rotor and plug wires.
      To have injector firing power must be present at each injector and ground
      pulses from the DME's pin 16 (Bank1) and pin 17 (Bank2) must reach the
      respective injector bank. Note that the injectors are wired as two banks of
      three. With cylinder 1,3,5 being bank 1 and 2,4,6 being bank 2. Power to the
      injectors is controlled by the main relay. Injector firing is best checked
      with a noid light.
      The fuel pump relay must have power on pin 86 (relay coil) from the main relay
      output (pin 87) and power on pin 30. The DME will ground pin 85 to turn on the
      relay and power the pump(s) via pin 87. Of the above, only the fuel pump power
      is fused. So if the there's power at pin 87, but not at the pump, check fuse
      11.
      The main relay and DME pin 18 receive power from the smaller of the two wires
      that connect to the battery's positive terminal. That wire incorporates an
      in-line fuse. When the DME is presented with a start signal, it grounds the
      main relay pin 85 and furnishes power to the fuel pump relay, injectors, and
      DME.
      Troubleshooting:
      Disconnect the battery and the DME cable. Then:
      1) Disconnect the coil negative and check continuity from that connector to
      DME pin 1. Also verify that from DME pin 1 to ground is an open circuit.
      2) Check the resistance across DME 47 & 48, which should be 500-560 ohms. If
      the CPS is dismounted, the resistance can be seen to change from about 500 to
      540-560 ohms when a ferrous object is brought to the face of the
      sensor. Neither pin should be grounded.
      3) Check for continuity from DME 36 to main relay 85 and from DME 3 to fuel
      pump relay 85.
      Reconnect the coil, remount the CPS (air gap should be 1mm), plug the
      relays back in, reconnect the DME, and connect the battery. Then do the
      following checks:
      1) With the key off, verify that power is present at DME pin 18 and main relay
      86 & 30.
      2) With the key on, verify that power is present at DME pin 27 and pin
      18. Power to pin 18 is from the main relay and there should be power to the
      injectors and fuel pump relay.
      3) With the key on, verify that no voltage is present at the DME grounds (2,
      14, 19, 24).
      4) Verify that power is present at the coil positive and at fuel pump relay
      pin 30. Those get switched power from the ignition switch via C101.
      The engine will start and run (if poorly) with only those connections to the
      DME in place. The other signals from Cylinder ID, AFM, temp sensor, etc., are
      necessary for proper operation. But they won't prevent the engine from firing.
      IMPORTANT:
      A power check means seeing a voltage within about a tenth of a volt of what
      you measure across the battery terminals, which should be at least 12.6v on a
      charged battery.
      A continuity check means seeing less that 1 ohm of resistance.
      An open circuit means seeing a resistance of at least 100k ohms.
      A good quality auto-ranging digital multimeter will make these tests much
      easier.
      • nunezfrancisco30
        • Mar 2013
        • 94
        Thanks guys it ended up being a bad ground to the fuel pump relay, now that it started I found it leaking huge amounts of oil out from between the head and bottom half of the engine, between cylinders 3 and 4 :'( just my luck, would you guys think it has something to do with a blown head gasket or much more serious?
          If the oil is wetting the side of the block from just below the headers and on down, it sounds like the head gasket. But if upper part of the block is dry, the leak could be at the oil pressure switch, oil filter, or pan gasket.
