adjusted my valves this weekend.
  • ///M42 sport
    • 3952
    finally got around to adjusting my valves again this weekend. Got my ticking to a minimum. The trick I found was to adjust the valves so that theres no play while the feeler gauge is under the rocker. That gives it the "slight" drag and makes it less of a subjective art.
  • dnguyen1963
    • Nov 2011
    • 2651
    There should be a bit of play with the gauge. It is a balancing act...too tight might lead to premature wear of your valve.
    • ///M42 sport
      • 3952
      The way I adjusted it, there was play without the gauge.
      • dnguyen1963
        • Nov 2011
        • 2651
        A bit too tight in my opion. E30 engine is meant to have a faint clacking noise at startup then goes away as the temp raises (with correct oil viscosity).
          The valves are correctly adjusted when there is a slight drag on the feeler gauge.
          • crazyman
            • Dec 2010
            • 738
            Not always, got my valves adjusted to factory spec and I run 10w-30w synthetic and I have absolutely no tick.
            85 swartz/metallic 325E
            84 alpine 325E
            85 zinnoberot 318i/R.I.P
            84 Bronzit 318i/sold
            purchase feed back here=http://www.r3vlimited.com/board/show...82#post3535282
            • dnguyen1963
              • Nov 2011
              • 2651
              I can adjust the valves to have no tick too, but with a slight drag on the feeler gauge you should hear a faint ticking noise at startup. I guess it all depends on how much rock and roll you have listened to.
              • crazyman
                • Dec 2010
                • 738
                I don't listen to music while I drive. I did have a slight drag on the feeler gauge but I should note that the eccentrics were replaced cus they are prone to developing flat spots.
                84 alpine 325E
