***UPDATED JUN 3RD*** SEE BOTTOM OF THIS POST***
Ok, R3V, I need your help.
Let me preface this with two disclaimers:
1. YES- I have searched extensively, and while there are an abundance of threads that outline possible causes, I've yet to find any with symptoms that exactly match mine.
2. I hereby swear, for the sake of future seekers, that I WILL update this thread when I've fixed the problem. Actually, if you're reading this months later and I haven't posted a fix, please PM me and I'll be sure to post it.
So settle in for my story, if you like:
Had my 84 eta for a little over a year, actually going on 18 months now. It's been troublesome, to say the least. Upon first purchasing, I changed all the operating fluids like a good e30 owner, plus made sure the timing belt/thermostat/water pump service was done. I've replaced coolant hoses, brake fluid, plugs, etc. You get the idea. The only thing I've yet to do is the distributor cap and rotor, and the O2 sensor.
I won't discuss upgrades in general since they likely have no bearing here, but one that might is the upgraded ECU from TMS. That being said I've run that nearly the entire time I've had the car with no issues- minus the week or so where I didn't realize I'd damaged my old ecu (it was a soldered board- it's a learning process, right?). Otherwise the motor is untouched.
The woes:
1. Blown Headgasket- fixed
2. Leaky/cracked oil pan- fixed
My most current woe: a crazy sputtering idle. Engine shakes and splutters and skips under load. It feels JUST like it did when I fried my DME. This started after I put a tank of 93 from Shell in it. Honest to God, after the oil pan job (shop job) I was enjoying the hell out of the car- it was revving freely, purring through corner, snarling on downshifts... ok it's an eta, so it doesn't do that much snarling- but you get it- the car was fine. So....
IMMEDIATELY after filling my tank the car started this monkey business. It would splutter and cough until it got hot. It would not overheat, mind you. But it would seem that there was almost a physical blockage or something that I had to blow through- again thinking a temperature-based thing. I drove it up to Road Atlanta for the weekend, where it performed admirably, though in the mornings I went through the same coughing spluttering fight. It mercifully made the trip up and back with no problems.
Which brings us to Monday, two days ago. When I parked the car sunday night, I assumed it would continue its pattern. Well, the next few times I tried it start it, on Monday, it would fire up to 2k RPM, then promptly die. It would either do that, or about every other try, would cough at normal (just shy of 1k) RPM for a few moments then die.
Searching yielded a few things to try.
I tried unplugging the AFM- no change. Tried unplugging the O2 sensor- no change. I tried multiple combinations of one plugged in, one disconnected- no change. So this morning I cleaned the ICV with carb cleaner. While doing so I decided to clean the intake butterfly while I was at it. While doing so I discovered a fairly sizable hole in the intake boot between the AFM and intake mani. I applied electrical tape to the intake boot, which covered the hole pretty well. Hopeful (but not very), I fired her up: and she maintained a weird rough idle. It sounded like it wanted to die, but then it would just barely sputter back to life. A spin around the block left me stalled mid-lane once and the engine choking a spluttering the rest of the way.
So- with the gas and the other stuff I've tried- tell me what to try next. If the general consensus is "smoke test" (looking at you Jim Levie), then that's what I'll do. But... I just can't get away from the facts: before tanking= fine; after tanking = horrible. Maybe try swapping fuel filter out before I do anything more expensive? You tell me.
I just want to say- I've been revived multiple times by this community. I've gone through some definite heartache and cash with this car. There have even been times where I've said "maybe I just got a lemon." I was perusing used-car ads last night in bed when my renewed vigor for e30 ownership came in this form: http://wheelmen.wordpress.com/
If you like vintage metal with a Bavarian soul, as I know you all do, you'll die over this stuff.
***UPDATE May 22nd 2013***
Had my car in shop for about 3 weeks now. Not happy about it. Here's what they've tried/found
1. Smoke Test/Intake Elbow cracked- easy fix
2. Injectors are getting fuel
3. Injectors are functioning properly
4. Spark is good
5. Crankshaft Position Sensors replaced- the guy realized that the tach wasn't registering any Revs despite the fact that he could hear the motor turning over. Led him to CPS
6. Replaced main relay
So before he did the CPS and Main Relay the car would sometimes maybe start, maybe not. Then after those two items were replaced it would start then operate smoothly for a few minutes before abruptly shutting off-
So I thought maybe my coolant temp sensor was bad. So I'm going to throw that part at it today, then report back.
*****UPDATE May 22nd #2*****
Shop threw the Coolant Temp Sensor on- no change whatsoever.
Should I try O2 Sensor, new CPS, new main relay, new Coolant Temp Sensor? Haven't messed with the O2 sensor...
********Update Jun 3rd- Car is Running Again!*********
Ok, so in an effort to keep my promise and increase the amount of usable data in the form of solutions on the site, I'm going to update and re-cap.
The symptoms- car was randomly skipping, stuttering, idling horribly, not starting or if it was starting, it would shut off after choking through a minute or two of running.
Initial Diagnosis- from a "old BMW guy" was that it was my valvetrain, which is VERY loud. It didn't end up being that, but I had the shop that adjusted my valves last doublecheck their work. So...
It was the two CPSs and the rotor.
The explanation- after initially doing smoke tests (they did several, they'd find leak, do it again, etc) and finding a minor intake leak in the intake elbow, the problem wasn't fixed. So the guy replaced the two Crankshaft Position Sensors. Unbeknownst to him at the time, one of the two CPSs came from the OEM parts dealer already fried. Don't ask me how he discovered it, but it "seemed" to fix part of the problem. So he swapped both CPSs and fired the car back up, it was running, but it was still skipping. So he went back to double-check the spark. Upon doing so he realized that the spark was intermittent, so it led him to the distributor/coil/cap area. Well, he knew the coil was working so he started at the rotor- it was fried. Simple fix, 50 dollar part and two CPSs later, the eta is purring smoothly along. As preventive maintenance I'll be installing a new distributor cap and ignition wires this week. All better!
