favorite poly motor mounts?
  • Wiglaf
    • Jan 2007
    • 1513
    So I've been running the IE mounts for a few years. I like them.
    I went to investigate some metallic loose/banging noises coming out of passenger front going over bumps and noticed one of my motor mounts is shredded. Time to buy new ones.
    While I liked the IE's, this is an opportunity to try AKG, Condor, etc. I don't want to go solid.. this is a vert and the chassis has some flex to it. The poly's transmitted a decent amount of vibrations but not too much, I think it's fun. There's turbos and autocross action involved here so I'm not going to fault the IE's, they lasted a few years. But if something has a design difference such as a metal bolt that goes all the way through it may last better.
    Suggestions?
    Originally posted by u3b3rg33k
    If you ever sell that car, tell me first. I want to be the first to not be able to afford it.
  • whodwho
    • Jun 2008
    • 1547
    These and never buy another pair again 8^)
    Been wanting to hit him up on a GB
    My M20 Frankenbuild(s)
    4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
    • Wiglaf
      • Jan 2007
      • 1513
      They look cool, but dang $250 is a lot. And there isn't much detail there about how it's built. How do I know it's not just a fancy housing for something that can still come apart?
      IE Urethane are $90.
      Condor UHMW is $45.
      AKG 75D $55 (says straight bolt thru)
      I'm leaning towards the AKG.
      I need an X-brace and new tires, don't want to blow my load on motor mounts. Because of my budget the $250 is gonna be a hard sell..
      • Earendil
        • 1662
        I have the condor ones. I've had them for only 50 miles or so and one track day. They felt and looked solid and quality. Not much else past that to say :)
        1989 - E30 - M20B25 - Manual. Approx 300,000+ miles - Track Rat & Weekend Fun
        2000 - E46 - M52TUB28 - Manual. Approx 130,000 miles - [not so] Daily Driver
        I'm looking for a Lachssilber Passenger Fender and Hood. PM if you have one or both to sell!
        • FLG
          • Sep 2011
          • 3165
          Condor.
          Yes you'll get some vibration (mainly coming off the clutch) but it's worth it. Feels great and you easily get used to it.
          Sent from my Galaxy Nexus using Tapatalk 2
          -Build http://www.r3vlimited.com/board/showthread.php?t=295277
          • Wiglaf
            • Jan 2007
            • 1513
            does condor's have the bolt go all the way thru?
            • Cabriolet
              • 9620
              what's wrong with rocking rubber mounts?
              Much wow
              I hate 4 doors
              • Earendil
                • 1662
                [Ignore]I'm not sure, but wouldn't that defeat the point of a bushing? Once the bolt goes all the way though you almost have a solid bushing, and you have metal from mount to frame.[/ignore]
                Edit2: On reflection, I'm being an idiot. The bolts certainly go all the way through the Condor ones I have. Nice tight fit too.
                • Earendil
                  • 1662
                  Absolutely nothing.
                  The only potential issue is what a failed bushing looks like. On a street driven, a bushing can fail almost without consequence. If you track your car however, you experience a LOT of deceleration that wants to move your engine into your radiator. Not only is this harder on a rubber mount, but the way they are designed, under really hard deceleration the engine can actually move away from the bushing. With most solid mounts there is a bolt that goes all the way through that would prevent that from happening.
                  And yes, I know we all like to think that we drive hard on the street. But when you threshold break from 120mph down to 30mph a couple dozen times in a day, you are certainly giving those motor mounts a larger work out. If you are inducing that much deceleration over that long a period of time on the street, you probably have bigger issues on your mind than a engine mount that moves a little too much :)
                  • SkiFree
                    • Jun 2011
                    • 2766
                    The ie mounts have gone through some redesigns in the last couple months. I'm finally happy with them. Given your mount issue, pm me and I'll see what I can do.
                    ADAMS Autosport
                    • offsetmotorwerks
                      • Apr 2013
                      • 27
                      AKG for everything. Had them multiple times, and nothing but great stuff to say about them! IE has redesigned their product, I have seem them in person and they are amazing, just haven't had a chance to try any of their modern poly.
                      • meengreene30
                        • Mar 2012
                        • 369
                        o
                        i've been running condor motor mounts and rubber e36 trans mounts now for 3 months. perfect combination.
                        • Bearmw
                          • 1323
                          I picked up some Revshift mounts that I'm going to be using withy my m30 and will report back in a month or so.
                          • Herr Faust Schinken
                            • Feb 2012
                            • 3580
                            Honestly I have AKGs and while they are beautifully made, they freaking suck to daily they vibrate the entire car so much, people that ride with me think something is broken, but the motor doesn't move at all
                            88 325is Five Speed
                            Lachssilber
                            • Wiglaf
                              • Jan 2007
                              • 1513
                              Turbo, autocross. And I just prefer to feel the motor vibration, it's fun. :)
                              Like all the other bushings I've replaced, I want to stiffen everything up.
                              Yeah? What's different? I'll PM ya.
