Smoke test showed smoke on ICV
  • Victor_PR
    • Jun 2011
    • 296
    Hi,
    I finally got to put my DIY Smoke tester to the test. I saw a leak towards the firewall side of the valve cover. Trying to remediate some of the leak I tightened the valve cover which - to my surprise - did accept tightening at all screws.
    The other place I managed to see the smoke leak was near the electrical harness connector on the ICV. Is this a common place for a leak? Is my ICV going south? Will silicone rtv help and if so, where do I apply it? While there I took it off and cleaned with throttle cleaner - which I had done not too long ago.
    Thanks for any light you can share.
    Victor
    Rides...
    E30 325i - 1990
    F30 328i - 2014 (DD)
    F25 X3 - 2016 (Family car)
    1974 - 2002 (The ruler of the stable) SOLD
    If smoke is leaking out of the ICV where the connector is, the ICV is worn and leaking. Replacing it with a new part would be the preferred fix.
    • Sagaris
      • Sep 2009
      • 2243
      FYI I also had a smoke test reveal an intake leak at the ICV plug.
