Fixed the temp sensor and swapped out the harness. Problem is still there. I have a appt with a shop in the morning.
Help!! Stumble/Cut at 5000 RPM
Well I found and temporarily fixed the problem. I put in a new crank sensor and the car ran/stumbled/cut different. So I tried to gap it and it would move to much. I put a washer inbetween the bracket and CPS and WALLA! It was fixed!! I raced this weekend and it stumbled again I added a second washer to pull it away from the Hamonic balancer and its fixed.
Turns out, my Harmonic balancer wobbles just a bit and causes the CPS to be to close or lose contact only at high RPM. I will be replacing the Harmonic Balancer and that way I have a good contact at .040. And I can lose the washers.
So after about 30 hours of work and about $400 of parts. It took a .10 washer to fix my prob!! Haha.
Thanks for all your help guys.Comment
