My 1988 325 is making a shaking sound whenever you start the vehicle, or when I turn the car off. I Don't believe its a Rod Knock or a Piston slap, as it only happens right when you start the vehicle or turn it off, and only for a second. It also happens when the RPMs are really low, as in like 300-500 (as in if it were about to die from letting clutch out to fast, low gear, etc).
It basically sounds like what a car sounds like when it wants to die and not idle, but only happens right away, my first suspect is a sensor has gone bad or is not working correctly, and ignition or fuel is off at low rpms.
someone help please
someone help please
