Need Help with Vacuum Control Installation
  • Quinthirty
    • Mar 2012
    • 318
    Hi,
    I'm trying to replace my vacuum control as the rubber hoses are old and brittle. When I was assembling the check valve control and installing the hoses, I noticed that the check control valve was not the same as the original. I checked the part number on Real OEM, and it was correct.
    Problem: there is a small tube at the bottom of check control valve that wasn't there in the original. Now I don't know what to do as how to plug it as I blew thru it and there's air going out of the other end.
    Would appreciate some help. Thanks R3V.
    (Sorry mods, I think I should have moved this to M20, but don't know how...pls feel free to move it. Thanks.)
  • KVF
    • 297
    Can't speak to whether or not that's the proper check control unit, but plugging that inlet/outlet is a simple as getting a small section of proper id vacuum hose and attaching via hose clamp; plug other end with proper diameter screw & hose clamp.
    • bmwstudent
      • Sep 2011
      • 1364
      Or a small rubber plug to go over top of it. Basically just cover it.
      • Quinthirty
        • Mar 2012
        • 318
        Would you recommend gasket sealer?
        • KVF
          • 297
          Sealant or silicone may come loose and get sucked into the system at some point. As mentioned above, some sort cap that you can secure would be best.
          • F34R
            sLaughter
            • 12376
            This^
            Listen up OP, this is how you plug small holes like that. Get a lighter and start burning the end till it melts a good ways back. Then take some pliers and smoosh the end. Works like a charm.
            Instagram: @BWeissLeather
            Current cars:
            ~ '87 325 M30B35 swap
            ~ '87 535
            ~ 01 540 Msport 6spd
            ~ '06 X5 4.8is
            • Quinthirty
              • Mar 2012
              • 318
              Thanks.
              • Quinthirty
                • Mar 2012
                • 318
                The best cap I found was a screw that fit quite snugly into the hole. I just cut a new portion of that had the gasket sealant so now its clean of any residue. Anyway, I also tried F34R's recommendation but the rubber hose just burnt off and didn't seal even with hard crimping from plier pressure.
