High RPM Stumble
  • Skunkworks
    • Sep 2012
    • 436
    High RPM Stumble
    my 87 325i 5 speed, Has developed a Stumble above 4k and will also stumble on lower rpm as well. I replaced the plugs and checked the wires, still the same symptoms.
    the other issue is that it is hard starting when its hot.
  • IP2GSR
    • Jun 2011
    • 31
    I had a stumble at 3500 rpm that turned out to be a faulty AFM. It is worth a try if you can get a spare
    • paperplane94
      • Jul 2011
      • 420
      This tells me that the Fuel Pressure Regulator is putting in too much fuel, which is probably also causing the stumble.
      Probably a tear in the Fuel Pressure Regulator diaphragm.
      • FLG
        • Sep 2011
        • 3165
        Hard starting hot is usually temp sensor, intake leaks, or leaky injectors.
        Have a smoke test performed, also you could verify sensor by checking it's resistance values and comparing them to spec (no idea what they are offhand)
        I'd have a smoke test done first and report back.
        Sent from my Galaxy Nexus using Tapatalk 2
        -Build http://www.r3vlimited.com/board/showthread.php?t=295277
        • 603Racing
          • Dec 2010
          • 612
          Throwing any codes? It should be.
          90 325i DD/Track
          03 Durango 5.9
          Originally posted by e30mpg
          It is recommended to get new gasket but this is R3v and we just copper spray that shit......slap biotch on and tighten to tq.
