oil cooler on all m20?
  • ///M42 sport
    • 3952
    I noticed on bmwfans that there s a hollow bolt available that goes where the oil cooler lines bolt in. Just wondering if all m20s had oil coolers.
    Nope, not all M20 engined cars had an oil cooler.
    • ///M42 sport
      • 3952
      earlier models? My oil cooler lines are leaking...
      • SkiFree
        • Jun 2011
        • 2766
        ADAMS Autosport
          • 37833
          M20B25 cars came with coolers.
          Grover Beach, California
          BimmerHeads.com
          • ///M42 sport
            • 3952
            anyone running without coolers have issues?
              In most cases one will not run into oil temperature issues w/o an oil cooler. I've run my Spec E30 (which has data logging) with and without an oil cooler (bigger than stock and in a better location) and haven't seen excessive oil temperatures. What I have seen is a rise in engine temperature and lower hot idle oil pressures.
              The most common failures in cars equipped with oil coolers are leaks in the hoses. The economical fix for that is to have the hoses rebuilt at a shop that does hydraulic hoses.
              • ///M42 sport
                • 3952
                meh, I think I'm going to delete the oil cooler. Its a daily only anyways.
                • Kevinl
                  • Oct 2012
                  • 897
                  Mine doesn't have an oil cooler? :hitler:
                  1989 BMW 325is Lachsilber metallic 5 speed
                  2007 BMW 335i KARMESINROT 6 Speed manual
                  2011 BMW X5 35I
                  • roznic
                    • Mar 2013
                    • 2879
                    I eliminated mine completely, and no issues..
                      • 37833
                      It did from the factory.
                      BimmerHeads.com
                      • Kevinl
                        • Oct 2012
                        • 897
                        Who knows what has been done in the past 24 years maybe they removed it or maybe I have a eta bottom end should I try to source another one? Or not bother
                        2011 BMW X5 35I
                        • ZM Blue Devil
                          • Dec 2006
                          • 13836
                          you can get a $8 piece to replace the oil cooler housing with the lines. We stock them :)
                          Levent
                          %20levent@gutenparts.com
                          Ladies:
