at what pressure does M20 oil press lite go on?
  • JRKOUPE
    • Dec 2004
    • 3159
    ..thinking of installing another light in dash (w/ a higher press sender), just to be safe on track. TIA
  • Jordan
    • 12912
    7psi, my VDO sender for the guage trigger the warning contact at 10PSI.
    https://mtechniqueabs.com/
    • JRKOUPE
      • Dec 2004
      • 3159
      Jordan
      ...the standard VDO sender for the m20 is set up at 10lbs or you installed a different sender? I recall your AC vent set up.....I imagine its hard to glance at while tracking car?.........are you using 100 or 80 lb gauge?......tia!
      • Jordan
        • 12912
        My guage placement is as good as it gets on a e30.. its very much in your immediate field of sight. Definately not in your ashtray...
        I have a 0-80PSI Oil Pressure guage, with a aftermarket VDO dual sender.
        The stock oil pressure switch is triggered at 7PSI.
        My VDO sender has one circuit for the guage, and a secondary switch circuit that turns the idiot light on at 10PSI.
        • JRKOUPE
          • Dec 2004
          • 3159
          gauges
          Jordan...
          thanks
