Recently swapped engine wont start
  • avRudy30
    • May 2013
    • 10
    Recently our mechanic had swapped my eta engine with another donor eta that was running fine. Now it wont start it cranks as long as i hold it but doesnt go any further than that. We checked all the sensors, replaced the ecu with original. Anyone else have this problem if so how did you solve it? What do you guys think
    Sent from my SGH-T989 using Tapatalk 2
  • Chriskbmx
    • Apr 2012
    • 972
    probably got the reference and crank sensor backwards on the bellhousing.
    • redhatpat
      • Aug 2005
      • 656
      It could be a lot of things, but the first thing that comes to mind, is make sure the CPS is connected and working.
        • 37828
        So did you check for fuel and spark? "Anyone else have this problem" is pretty damn vague.
        Classic BMW Specialists
        Grover Beach, CA
        www.BimmerHeads.com
        • Playgunz
          • Jun 2013
          • 23
          If this guy didn't have such a sweet azz car I would say he is kinda mean, but..... He is a mod and has a nice azz car so I say quit being so dang vague, lol.
          • avRudy30
            • May 2013
            • 10
            lol no offense is taken, i am still new to cars/e30s so i have no problem accepting the noob license
            everything is fine as far as I know, we checked over all the sensors, replaced sparkplugs, reset electronics and other stuff as well. my mechanic is saying it has to do with the computer getting used to the new motor, but I thought i'd just see if this was usual with swapping motors or not.
            • dnguyen1963
              • Nov 2011
              • 2648
              I think he meant "Does anyone else have this problem?".
              • UserError
                • 86
                Frankly, your mechanic is BSing you. My first guesses would be a crank sensor going out, or a fuel problem. The easier one to eliminate would be a fuel pressure issue. Go to the auto parts store and get a fuel pressure gauge. You'll also want to get an 8mm (or 5/16 inch) T fitting, a piece of hose, and a can of starting fluid. Crank the motor over, and see if you get pressure. If you don't, then take the intake hose off and spray a bit of starter fluid onto the throttle plate. Try again. If it starts and then dies, then the fuel pump is bad.
                If it doesn't start, then you need to check spark. Take one of the old spark plugs you replaced, and pull the #2 spark plug wire from the plug. Touch the threads of the plug onto a metal piece of the engine, the valve cover works fine for this. Have a friend/enemy/family member crank over the engine, and look for a blue spark at the end of the plug. It helps a bit if it's dark when you try this. If you don't have spark on #2, check on #1. If you have spark there, then it's a bad crank sensor (your mechanic should've replaced them when they did the motor, anyway). If there's no spark on 1 and 2, then plug the spark plug wires back in, and check for spark at the coil. Same procedure, more or less, though you need to pull the coil wire off of the distributor. If there's spark there, then you need to start by replacing the cap and rotor, and go from there.
                Why isn't the mechanic doing this, anyway? They put the motor in, they should make sure it runs before you get it.
                • 603Racing
                  • Dec 2010
                  • 612
                  10 to 1 something isn't connected properly. Just curious, what is the production date of your car and the donor car?
                  Go with UserError's suggestions, check for fuel and spark. You will have not have one or the other (or both).
                  90 325i DD/Track
                  03 Durango 5.9
                  Originally posted by e30mpg
                  It is recommended to get new gasket but this is R3v and we just copper spray that shit......slap biotch on and tighten to tq.
                    • 37828
                    As I said the first thing you need to do is check for spark and check for fuel.
                    Grover Beach, CA
                    www.BimmerHeads.com
