Well since the guys at the shop where I currently have the car couldn't figure it out I'm hoping that my fellow r3vlimited friends can help out. The shop was trying to bleed the system and had no luck, apparently it only steams out of the bleeder on the thermo housing. No antifreeze comes out, and since I have an m42 radiator it has another bleeder on the radiator,however only huge amounts of bubbles come out the built in expansion thank. It only takes 4 to 5 minutes for it to start heating up. The guys there believe it to be a blown head gasket, but I just replaced it before taking it to them! another thing they can think of is a bad thermostat and bad water pump. any ideas guys?
System just won't bleed!
Tags: None
yea they resurfaced it and found no cracks, the tech at the shop suggested double checking the type of head gasket I used. I used the one from victor reinz, with new head bolts, torqued them down to 22 ft/lb, then angle torqued twice to 90 degrees.Comment
VR head gasket problems seem to mostly be oil leaks. I've used a number of VR gaskets, as have others and never had a problem.
The definitive test for cracks in the head is a pressure test, the next best alternative is a dye penetrant test. A simple visual inspection will only find gross cracks, which is what is most commonly done.The car makes it possible, but the driver makes it happen.
Jim Levie, Huntsville, ALComment
Did you take off the top rad hose and fill the system from coolant there? also helps to pull the hose on the other side of the thermostat and fill from there. The thermostat needs to be submerged in hot water to open to bleed the system. thermostats won't open in hot air.Comment
this.Did you take off the top rad hose and fill the system from coolant there? also helps to pull the hose on the other side of the thermostat and fill from there. The thermostat needs to be submerged in hot water to open to bleed the system. thermostats won't open in hot air.
Fill the upper heater core hose first. Then the top radiator hose.
It also moves thing quicker when you use warm/hot water to fill.
You should run the heater on full blast when bleeding the system, if you/they haven't been.
To the points already made, if you're only getting steam it's either a leaky head gasket or there's not enough coolant in the system.90 325i DD/Track
03 Durango 5.9
Originally posted by e30mpgIt is recommended to get new gasket but this is R3v and we just copper spray that shit......slap biotch on and tighten to tq.Comment
