M20 2.7 vac hoses
  • LateFan
    • May 2013
    • 4422
    M20 2.7 vac hoses
    Is there a list of which diameters and how much hose to buy to replace all vacuum hoses? Parts sources just show bulk hose by the foot, but not how much you need.
    Also, I don't seem to be able to find a vacuum hose diagram for an '86 ES on realOEM. Everything else on the engine - fuel lines, etc, but I don't see vac lines.
    Any ideas where to look?
    Thank you -
  • FLG
    • Sep 2011
    • 3165
    You can buy a complete silicone kit from a few sources, not sure on quality but they seem like good pieces. Just search e30 silicone vacuum hose kit.
    If you want oem just get in touch with steve at blunt, im sure he can look up the parts and get all the hoses you need.
    -Build http://www.r3vlimited.com/board/showthread.php?t=295277
    • LateFan
      • May 2013
      • 4422
      Thanks, I've seen some of that. I'd rather stay with straight OEM stuff. I see Pelican has Conti hose in all different diameters, but they can't tell me how much I need.
        • 37833
        http://realoem.com/bmw/showparts.do?...28&hg=13&fg=15
        http://realoem.com/bmw/showparts.do?...38&hg=11&fg=15
        The above links should help for the specific hoses.
        For the FPR hose you can use generic 1/8" vacuum line.
        For the throttle body to fuel tank vent you can use generic 5/16" line.
        Grover Beach, California
        BimmerHeads.com
